944 & 944S Forum 1982-1991
1984 Porsche 944 flywheel
Old 10-30-2017, 07:37 PM
bzlee
6th Gear
bzlee's Avatar
Default 1984 Porsche 944 flywheel
Hey Guys,
Im replacing my clutch so i figured i would get a rear main seal and a new flywheel while everything is apart.
Does anyone have any links/recommendations on the ones out on the market?
Ive seen the light weight aluminum ones and the normal steel ones. The main two arre spec and fidanzza.
Has anyone had any experience with either?
Is the light weight worth it?
Thanks,
Old 11-03-2017, 03:30 AM
mel_t_vin
mel_t_vin's Avatar
Originally Posted by bzlee
Ive seen the light weight aluminum ones and the normal steel ones. The main two arre spec and fidanzza. Is the light weight worth it?
What are you planning to do with your car...street, autocross, or race?
For a track car...LWFW is probably worth it [pending your skill set].
For the street...not so much. On the street, the heavier rotating mass of the OE flywheel is your friend. YMMV...
Old 11-06-2017, 02:34 PM
Funn944
Funn944's Avatar
I have used the lightweight Fidenza on the street for at least 7 years with no problems.
Quick Reply: 1984 Porsche 944 flywheel
