944 & 944S Forum 1982-1991
Interest in 3D printed spark wire holders?
Old 11-14-2017, 10:24 AM
dreygata
dreygata's Avatar
Default Interest in 3D printed spark wire holders?
I'm having a friend 3D print the two fuel rail mounted plastic spark wire holders and the one on the front cam housing. I wanted to gage people's interest in buying these for less than you can find on pelican parts.
Old 11-15-2017, 01:37 AM
mj951
mj951's Avatar
I'd be interested in a set.
Old 11-15-2017, 09:09 AM
931guru
931guru's Avatar
Nope.
Old 11-15-2017, 12:24 PM
PaulD_944S2
PaulD_944S2's Avatar
Several sets, but what is estimated cost, and availability?
Old 11-15-2017, 09:18 PM
924martinirossi
924martinirossi's Avatar
OK
Old 11-15-2017, 09:19 PM
924martinirossi
Only if they can withstand under hood temps and accept wire sizes 8mm or larger...
Old 11-16-2017, 09:02 AM
dreygata
dreygata's Avatar
Mostly seeing how much interest there is (which determines cost via quantity).
It'll be ABS plastic I believe, and I'll test it out before I sell them, since I don't want to give anything that's going to fail.
As for wire size accommodations, it's going to be the exact same as the stock versions
Old 11-16-2017, 10:36 AM
dreygata
dreygata's Avatar
Going to experiment with a couple different plastics actually, But we'd likely sell them as a set of 3 (the two on the fuel rail and the one on the cam housing). Probably around $15 for a set of 3 or $5 each.
$15 for a single piece from pelican seemed absurd to me.
Old 11-16-2017, 12:47 PM
PaulD_944S2
Can you you double shot molding where a legend in white is embedded in black body?
Something great would be replacement buttons for the heater/air conditioning control unit.
Quick Reply: Interest in 3D printed spark wire holders?
