944 fender rust
944 fender rust
I am new to the forums and a new to 944’s
i bought a 944 recently for a good deal and I have discovered some rusted out spots along the fender wells and some areas underneath the door skirt. this was all covered up with a Porsche decal so I didn’t catch them unfortunately until I removed some of the decal. The worst spot is drivers side front fender well.
I have attached 3 videos. One tracking down each side detailing the rusty spots and checking sturdiness. And one that show a little rust in the door sill but none in the vented area in the sill. I will attach some pictures as well. One of door driver door sill
videos:
https://youtu.be/vh4rHrpEQd8
https://youtu.be/-Ly-qcpN26w
https://youtu.be/a8QDVdBLZKM
1. From what you can see here. Does it look like any structural rust has happened? From what I can tell the rust is the lip side that goes out towards the fender and not the frame itself.
2. What is the best course of action to fix this? I have searched the forums and the internet and have found some helpful info but I wondering if anyone here has any first hand experience with a repair like this. The car needs a lot of body work to begin with and will need a repaint and I was okay with that for a long run project, but this is a little more than I bargained for. Is it easy enough for a body shop to remove those pieces and fabricate new piece and weld in? I do no have any experience with this and wondering if it is worth it.
Thanks for any help here.
Sill
Sill vent
Rear drivers fender well
Front driver side fender
Underneath decal is rusted
and others of rust and exterior.
videos:
Sill
Sill vent
You wont know how extensive the rust is until you start grinding. The fix is to cut out all the rust and re-weld new metal into those areas, bondo, sand and paint. The worst looks to be the rocker panels.
If you start grinding out the rust and discover its just surface rust and has not gone all the way through you can seal or bondo it and repaint.
Glassmuseum (08-02-2022)
videos:
Sill
Sill vent
videos:
Sill
Sill vent
Adding in an addendum here. I am trying to track down why the rust even happened in the first place. Did a quick test and sprayed some water in the door jam against the front fender and the water is draining right in that same bad spot where the front fender and frame meets. Is there a seal missing somewhere here? I should also add that this happens when the door is closed.
video here
video here
What are your concerns -- that the rust will get worse over time if it's not fixed, that it detracts from the appearance of the car, or are you looking to sell in the future and want a better valuation?
If you were to pay somebody else to fix the body, rust, and repaint it, IMO the cost would likely exceed the value of the car. You could do some of the prep work yourself and save some money, or do all the work yourself.
IMO if it's minor fender rust, the car is not going to collapse into pieces in a few years, or even 10 years. You can take an ice pick or screwdriver and see how far you can push into the corrosion, and check areas where it's important there be no rust.
Personally I would drive it and enjoy it. That's actually not a bad looking car.
That does not look good. Worst of all is that rust has been covered over once and is reappearing. The best way to make an accurate assessment will be to remove the front fenders and fully expose every other area that is showing corrosion and go from there. If the mechanicals and interior are good, it may be best to start with a better shell and transplant the good parts of this car.
Definitely okay with having some pending body work and not even in a hurry but just trying to make sure it’s not completely out of reach I suppose and if it’s worth pursuing.
