Instrumentation panel went bad
Took the instrumentation panel to fix the odometer gear. When putting the cluster back into the dash, none of the needles move, there is no light except the left.
i wonder if one of the 3 connectors can loose.
also, the speedometer needle broke. I used a straw to epoxy it together but needle doesn’t automatically return to 0mph.
should I get a new instrumentation panel?
944 s2
944 s2
Took it out again and now the speedometer is still not working and airbag/seat belt light is still on. Everything else is working.
The speedometer needle broke and I repaired it. But it’s not moving. It was moving when I used my finger before reassembly.
Any ideas on the warning light and where to get a speedometer?
