Throwing this out there $?
'86 N/A possibly going on the market. Over 200K miles Fiberworks front and rear molded into the body, body needs some work. Paint is 4 years old. Early turbo phones, with 245/50/front, 255/50/rear BFG Sports that need replacing. MSDS header 3"exhuast w/cat and Walker muffler. MSD ignition, overbored throttle body, adjustable FPR. Auto Meter Cobalt wide band AFR guage mounted in pod on windsheild post. Good windshield w/antenna in glass, radio with MP3 player input. Vinyl Cerullo GT Sport seats. Halon fire extinguisher. Fidenza light weight flywheel, new style clutch w/ short shift kit. Brand new water pump, rollers and belts, still overheats, probably head gasket. AC delete, cone air filter. Have the fixed headlight buckets (not installed). Ground control camber plates, Weltmeister 250lb front springs on Koni sports all around, lowered with eccentrics, Weltmeister stage II sway bars front and rear. Fairly new Rennbay ball joints, Weltmeister A-arm poly bushings. Rennbay front big brake kit w/ Zimmerman crossdrilled rotors all around, Hawk rear pads. Braided stainless brake lines. Lindsey fuel lines, and new fuel pressure guage on the fuel rail. Have new gearboxes (not installed) for sunroof. Electric door locks w/LED locked indicators on door panel. G-Force 5 point harness.
Currently located in L.A. CA
Any thoughts, takers ??
