944 & 944S Forum 1982-1991
Removing lower half of rear seat?
Old 03-20-2017, 01:38 AM
BlackOp
BlackOp's Avatar
Default Removing lower half of rear seat?
I'm removing my rear seat and have taken out the two inner seat belt bolts. Is there anything else that is holding it to the car?
I read that you just need to pry the seat off at this point but didn't want to risk damaging it.
Thanks!
Old 03-20-2017, 05:28 AM
ealoken
ealoken's Avatar
Just the two bolts, my needed some gently pulling.
Old 03-20-2017, 09:33 AM
931guru
931guru's Avatar
Glue
Old 03-20-2017, 11:18 AM
V2Rocket
Rainman
V2Rocket's Avatar
there is a LOT of glue holding the cushion to the car metal.
luckily it isn't super sticky at this age and so with good pulling it lets go without ripping up the seat foam.
at the top edge (where the seat meets the trunk floor) there are a few metal clips holding the vinyl to the trunk floor, remove those and then you can reach down behind that "flap of vinyl" that was clipped down to start separating the seat from the car.
Old 03-20-2017, 01:28 PM
BlackOp
BlackOp's Avatar
Thanks!!
Quick Reply: Removing lower half of rear seat?
