Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > 924/944/951/968 Model Specific Technical Forums > 944 & 944S2 Forum
Old 11-17-2009, 01:31 PM   #1
madd9999
New User
Default Tips: oil in coolant 110k miles
Hi,
I have read some threads on this topic: "oil in coolant"...but I don't get any good tips on how to come around the problem.
From what I have understood the oil cooler seal could be one critical part to oversee??
I haven't yet done anything about it but I'm going to and I need help, guys...where to look for possible leakages and parts to change?
I also have, what I think is oil consumption in the engine..there is a small leak but I think most of the oil ends up in the coolant.
Can anybody give me some concrete tips on what to do/look for/replace??
Thank you!
madd9999 is offline   Reply With Quote
Old 11-18-2009, 10:59 PM   #2
Stephen Porter
Stephen Porter's Avatar
Quote:
See info at Clark's Garage:
http://www.clarks-garage.com/
Update kit is at:
http://www.rennbay.com/944-oil-coole...kit-p-131.html
Very common failure with 944's and a (fairly) easy fix.
HTH.
Stephen Porter
Los Angeles, CA
1988 928 S4 -- "Sharky"
1988 924S -- Daily driver
Previously: Lots of 951's, 944S2's, 2 914's and one Boxster S.
Rennlist Member/PCA Member
Stephen Porter is offline   Reply With Quote
Old 11-25-2009, 08:59 PM   #3
pnbell
User
pnbell's Avatar
Oil will float on top of your coolant, as oil is less dense... Look for this in your coolant tank.
If you do find oil in your coolant!!!! This is very BAD! fix the problem asap, change the oil, and cross your fingers...
As I said oil floats on top of coolant- so the coolant will settle in the motor and DESTROY your Main and Rod bearings!!!!!
Look for leaks under the engine/passengers side/behind oil filter. There is a rectangular housing on the engine there... This is the oil cooler. the seals inside seperate the OIL and Coolant
pnbell is offline   Reply With Quote
Tags
944s2, boxster, coolant, float, floats, happen, oil, porsche, put
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
