Porsche 944 Turbo restomod
Old 08-14-2019, 10:14 AM
  #166
Paulyy
Professional Hoon
Paulyy's Avatar
went though the same problem with the ceramic in the head. got a new one, that eventually broke off too.
Old 08-15-2019, 03:39 AM
  #167
Frank@Work
Frank@Work's Avatar
That's my concern!
What damage did it cause to the turbo/engine?
Old 08-15-2019, 02:35 PM
  #168
Chapman951
Chapman951's Avatar
Beautiful car and i'm looking forward to your engine build.
A lot of people install a steam vent kit on our cars as well. https://www.lindseyracing.com/LR/Parts/COOLSTEAM.html
Old 08-16-2019, 07:03 AM
  #169
H.F.B.
H.F.B.'s Avatar
Originally Posted by Frank@Work
I have checked out several heads (already) and they all have the ceramic problem!
Why would I be replacing my broken head with a head which will eventually brake as well?
I'm considering a NA head for my build.
Any reason why I should not be using a NA head?
Just a hint regarding the different check valves in case you use a NA head. So change the check valve too.
951 oil check valve vs. 944 oil check valve
Old 08-23-2019, 10:11 AM
  #170
Frank@Work
Frank@Work's Avatar
I have found a good NA cylinderhead and have dropped it off (with my Turbo cylinderhead) at the rebuild shop. Next week it will be back.
Old 08-31-2019, 11:24 AM
  #171
SeaCay
Thefu
SeaCay's Avatar
You've done well to introduce air to the transaxle cooler, but where does the air exit?
Old 09-01-2019, 05:55 AM
  #172
Frank@Work
Frank@Work's Avatar
The air will exit through the diffusor.
Old 09-08-2019, 04:53 AM
  #173
Frank@Work
Frank@Work's Avatar
Can someone show me/tell me where these springs go? It should be somewhere near the bumper.
Old 09-08-2019, 08:11 AM
  #174
black944 turbo
black944 turbo's Avatar
They go in between the cover and reinforcement if memory serves me correctly. It has been many years since I took the bumper off one though.
Old 09-08-2019, 09:05 AM
  #175
Frank@Work
Frank@Work's Avatar
That’s what I was afraid of. Taking off the bumper.
Thank you.
Old 09-08-2019, 09:17 AM
  #176
Frank@Work
Frank@Work's Avatar
Ah, I don’t need to take the bumper off. The clamps are for the water hose for the headlight washer system. Which I don’t have! :-)
https://cdn4.pelicanparts.com/techar...mall/pic07.jpg
Ignore the arrows in the oicture. The clamps are at the top of the bumper.
Old 09-16-2019, 05:16 PM
  #177
CyCloNe!
CyCloNe!'s Avatar
nvm had a response but just noticed the OP figured it out lol.
Old 10-04-2019, 04:49 AM
  #178
Frank@Work
Frank@Work's Avatar
The (stock) engine build is coming along. I will try to post some pictures this weekend so y'all can point me out where I'm f'ing things up.
I have wired in the Zeitronix ZT-2 and will be ordering a LCD display it. I was wondering if someone has managed to replace the stock O2 sensor signal with the narrow band outout signal from the Zeitronix. Will this work? Can I just replace the stock O2 sensor with a screw plug and leave the O2 connector in the harness disconnected?
Old 10-04-2019, 05:32 AM
  #179
PF
PF's Avatar
I used the ZT2 display like this in my Turbo Cup and 968 Turbo S replica. Kept the stock narrow band and added an extra bung for the wideband in the exhaust.
Old 10-04-2019, 12:38 PM
  #180
Frank@Work
Frank@Work's Avatar
I don't like to be dictated on the way I should be wiring my injectors. The LR billet fuel rail bracket only allows me to connect the injecor wiring from the side where also the sparkplug wires are routed.
A small modification of the bracket did the trick.
The stock NA head is on!
New waterpump.
The headers have not been coated. Only painted to see if I like the looks. For the final (3.0) build I will have the (aftermarket) exhaust system coated with Zircotec.
I love (cheap) tools!
mj951 (10-04-2019)
Quick Reply: Porsche 944 Turbo restomod
