Can I NA my Turbo?
Old 07-23-2018, 12:48 PM
chrenan
chrenan's Avatar
Default Can I NA my Turbo?
I've run a 1987 944 Turbo as a street legal track car for the last 11 years. It's been good to me and I've got it setup to be a perfect dance partner. I've kept up on engine maintenance over the years, rod bearings, head gasket, fresh head and turbo etc. A driver side balance shaft leak and a few others have been getting steadily worse, so I really need to pull the engine and address it. While the engine is out, I'm wondering can I NA it to simplify things?
Some details on my car ->
Front Suspension:
400in/lbs springs
Racers Edge Camber Plates / High Strung 44 Control Arms with monoball bushings
Ground Control coil over / Koni Sport
30mm front sway bar
Rear Suspension:
650in/lbs springs
Elephant Racing Poly Bronze Bearings / Solid torsion carrier mounts and monoball bushings
Ground Control coil over / 30 series Koni
19mm adjustable rear sway bar
Weights:
Corner balance:
818.....810
782.....747
Cross weight 50.4%
Total weight 3157 including half tank of gas and 215 for driver (2942 without driver)
Brakes:
Front:
996 GT3 4-Piston calipers on 330 Cayenne rotors
Pagid Orange pads
944 Turbo Cup cooling ducts and 968 air spats
Rear:
Stock 944 Turbo calipers and rotors
Pagid Black pads
Safety/Interior:
Heigo bolt-in rollbar
Cobra Evolution GT halo seat
Scroth harnesses
Momo Mod 07 wheel on NRG quick release
Transmission:
Stock 944 Turbo with added Quaife TBD
Steering:
Factory manual steering rack
Wheels:
993 narrow body fitment Hollow Spokes - 8" front 10" rear (no spacers)
fasteddie313 (07-29-2019)
Old 07-23-2018, 01:00 PM
Tedro951
Tedro951's Avatar
For sure! Then again, I've never driven a 100 hp car that weighs 3000lbs.
Old 07-23-2018, 01:13 PM
chrenan
chrenan's Avatar
That’s a definite concern I have. So I called the NA store and ordered a large box of NA.
Old 07-23-2018, 01:16 PM
V2Rocket
Rainman
V2Rocket's Avatar
what else are you planning to do?
addressing all oil leaks, new clutch, etc can be done over a weekend and you'll be driving in boost again by monday.
putting another engine in that youll just take out later adds lots of complication?
and even running the 8:1 block non boosted would still give you in the 130hp range.
Old 07-23-2018, 01:30 PM
chrenan
chrenan's Avatar
I’m planning on making some changes to the exhaust system so I can run a second set of headers.
Old 07-23-2018, 02:15 PM
V2Rocket
Rainman
V2Rocket's Avatar
LOL got it
Old 07-23-2018, 02:17 PM
chrenan
chrenan's Avatar
LOL got it
Old 07-23-2018, 02:34 PM
931guru
931guru's Avatar
As a PCA tech speaker once said, "An NA car just has infinite lag."
Old 07-23-2018, 03:27 PM
chrenan
chrenan's Avatar
Big radiator to keep things cool.
Old 07-23-2018, 03:29 PM
chrenan
chrenan's Avatar
Swap oil pan, 4 trap doors, one in each corner of the sump.
Old 07-23-2018, 03:32 PM
chrenan
chrenan's Avatar
I should pull that LS2 out of the box...
Old 07-23-2018, 03:33 PM
chrenan
chrenan's Avatar
Slap that pan and cross member on...
Old 07-23-2018, 03:35 PM
chrenan
chrenan's Avatar
Need to line things up just right, don't want to dent those long tubes or crack that new radiator...
Old 07-23-2018, 03:36 PM
chrenan
chrenan's Avatar
Then tighten the mounting bolts...
Old 07-23-2018, 03:37 PM
chrenan
chrenan's Avatar
Put the car back on the ground...
Quick Reply: Can I NA my Turbo?
