85.5+ AC fan cycling switch
Old 08-12-2018, 06:33 PM
dvarholy
dvarholy's Avatar
Default 85.5+ AC fan cycling switch
Apparently, the 94465305300 fan cycling switch used on my '86 951 is NLA. Has anyone discovered a suitable replacement? Commercial HVAC fan cycling switches are also this 1/4" female flare type. There may be a switch from some other make and model that will work? The factory manuals are no help. I am a 20 year HVAC tech.
Daniel
'86 951
'82 931 (long gone)
Old 08-12-2018, 06:45 PM
PaulD_944S2
PaulD_944S2's Avatar
Try
https://plyhammersparts.com
or
https://www.porsche944usedparts.com/apps/webstore/.
They are very reasonable used parts vendors and great guys.
Old 08-12-2018, 10:09 PM
Tedro951
Tedro951's Avatar
Try SW 9052C
Old 02-27-2019, 09:32 PM
dvarholy
dvarholy's Avatar
I ordered the Temp 901409 (which crosses to SW 9052C) fan cycling switch from NAPA. No specifications were listed on their website, so I had to buy it to find out. The closing pressure is 260 psi! This seems rather high for an R12 or even R134a system? Has anyone actually here used this switch? I am afraid of hose/shaft seal/safety valve issues on this 33 year old car? Does anyone know the pressure ratings of the OEM switch?
Daniel
'86 951
'82 931 (long gone)
Old 02-28-2019, 10:11 AM
Dan Martinic
Dan Martinic's Avatar
Originally Posted by dvarholy
Apparently, the94465305300 fan cycling switch used on my '86 951 is NLA. Has anyone discovered a suitable replacement? This switch directly controls the condenser fan motor
Pardon my ignorance: what is a "condenser fan motor"? By condenser, do you mean the AC "rad" located in front of the regular cooling rad? I don't think the AC condenser has a separate fan?
Old 02-28-2019, 12:06 PM
gruhsy
gruhsy's Avatar
I believe when you turn on the A/C the radiator fans turn on whenever the A/C is running.
The condenser "hot" is the rad in the front. The evaporator "cool" is the rad in the firewall plenum thingy bobber.....I removed that assembly on the RAGE2 car recently.
Hence you want to remove the heat from the condenser and air traveling past the evaporator cools down and cools down the cabin.
Old 02-28-2019, 12:12 PM
Dan Martinic
Ok.. so the OP is referring to a switch in the AC system that activates the regular cooling fans in front.. ..and his concern is the one he ordered may wait too long to turn those fans on (the pressure spec)? However, if the rad fans run with the AC on anyway, I assume this extra switch is redundant?
Old 02-28-2019, 01:21 PM
MAGK944
MAGK944's Avatar
Turning on the AC switch puts a signal to the fan relay to turn on one cooling fan to high. There are two other switches in the AC circuit, a high-pressure switch and a high-temperature switch, both are by the dryer canister. If these switches are activated they send another signal to the fan relay to turn on the second cooling fan to high also. So those switches are not redundant, they are a safety feature to prevent over-temperature or over-pressure in the AC system.
Old 02-28-2019, 02:14 PM
Dan Martinic
Good to know.. thanks. I'm curious if the NAPA part is sufficient for this purpose
Old 03-01-2019, 12:24 AM
dvarholy
dvarholy's Avatar
I will try to find a different switch which is closer to the factory 94465305300 closing pressure of 14 bar (210 psi). The NAPA 901409 switch closes at 18 bar (260 psi). R12 is a relatively low pressure refrigerant not intended for use at such high pressures and temperatures. At 260 psi, the R12 condensing pressure is 160F. Both of these figures are too high for my liking. After looking at various HVAC catalogs of fan cycling switches, I will try Johnson Controls # P100AP-359C which closes at 215 psi and is almost spot on to the original pressure specification.
Daniel
'86 951
'82 931 (long gone)
Old 03-01-2019, 08:51 AM
Dan Martinic
You still have R12 in there? Interesting
Old 03-01-2019, 01:37 PM
dvarholy
dvarholy's Avatar
I have been HVAC tech for many years and have recovery equipment plus a supply of R12. Strange that the manuals say '86 and prior used a temp switch for fan cycling. The pressure switch I am replacing does not appear in the manuals until '87. Everything looks original with no changes to the wiring harness.
Daniel
'86 951
'92 931 (long gone)
Old 03-01-2019, 02:24 PM
MAGK944
MAGK944's Avatar
....Strange that the manuals say '86 and prior used a temp switch for fan cycling. The pressure switch I am replacing does not appear in the manuals until '87....
Half way through ‘85 is when most things changed, commonly known as 85.5 but I’ve seen it referenced as ‘86 in the Manuals also
’87 was just the offset change to accommodate ABS.
Old 03-01-2019, 04:50 PM
dvarholy
dvarholy's Avatar
That may be why Fuchs wheels were only offered in '86?
Daniel
'86 951
'82 931 (long gone)
Old 03-01-2019, 06:26 PM
MAGK944
MAGK944's Avatar
Daniel
'86 951
'82 931 (long gone)
Fuchs were an option from ‘82 to ‘86 but not after the offset change in ‘87.
Quick Reply: 85.5+ AC fan cycling switch
