Bucking under acceleration
Old 08-26-2018, 01:00 PM
spencang
spencang's Avatar
Default Bucking under acceleration
I have searched and read several posts about this problem. I checked all of my intake hoses and I also just installed the LR silicone J boot (I had this issue before I got the new j boot).
But I still am getting bucking when I accelerate from 3k rpm to 3800. If I go WOT below that, I get normal acceleration all the way to redline. But if I'm cruising at 3k, then go 3/4 to WOT, I get bucking at 3800 or so. It's almost like it's the overboost or rev limiter.
Any and all help is much appreciated.
Old 08-26-2018, 02:53 PM
Humboldtgrin
Humboldtgrin's Avatar
Sounds like a worn out potentiometer in your AFM or TPS. You can test them with an analog ohm meter. A digital ohm meter is not accurate enough when testing a potentiometer unless it’s an oscilloscope.
Old 08-26-2018, 04:53 PM
spencang
spencang's Avatar
I'll test it per Clark's Garage. Thanks
Old 08-26-2018, 06:50 PM
spencang
spencang's Avatar
I tested it, per Clark's Garage and it passed. No fluctuations as the barn door opened.
Anything I should be looking for?
Old 08-26-2018, 07:59 PM
Humboldtgrin
How are your plugs and plug wires looking?
Old 08-27-2018, 10:35 AM
Willard Bridgham 3
Willard Bridgham 3's Avatar
Have you checked for air leaks in the air/turbo system, both positive and negative pressure?
Old 08-27-2018, 06:47 PM
spencang
spencang's Avatar
I change my plugs annually and I put new 9mm wires on in 2012. They plugs/wires are connected nice and solid.
I'm not sure how to check the turbo system for positive and negative pressure leaks. How is that done?
Old 08-28-2018, 09:15 AM
Humboldtgrin
Five years on those wires might be the issue. It very well could be that easy. How many miles have you driven it in the last five years? I only mention that because electricity takes the path of least resistance and at 3000 to 3800 rpm’s is where the engine produces the most torque meaning the most resistance in the cumbustion chamber is happening. Take a look at them to see if there looks to be a vary small black spot on one or more of them where they could be grounding to the fuel rail mounts or anything else they could rubbing against.
Old 08-28-2018, 10:40 PM
spencang
spencang's Avatar
I've put on less than 10k miles since then. Is there a way to check resistance or is it as simple looking for burn/black spots on the cable?
Old 08-28-2018, 11:19 PM
Humboldtgrin
Yea I don’t think that’s your issue with that low of miles. Geez has your fuel turned to turpentine?
Old 08-29-2018, 12:44 AM
Tom M'Guinn
Tom M'Guinn's Avatar
I've had ignition missing/bogging from wires that look great and spec out on the ohm meter, so not sure there is any practical way to know if yours are bad other than trying new ones. You can try looking for arcs in the dark, but chances are they are fine until your motor sees a lot more load than you can get in a dark driveway... If yours are from 2012, it wouldn't be a waste to change them anyway.
Old 08-29-2018, 06:43 PM
spencang
spencang's Avatar
I looked at Automotion's and Lindsey's website and there seems to be a lot to choose from. I have an MSD ignition and a Blaster 2 coil (new coil as of last summer). Any recommendations on new wires?
Old 08-29-2018, 11:28 PM
Humboldtgrin
Isn’t there supposed to be a risistor on the power wire to the coil if you use an MSD Blaster coil? Maybe not if an MSD spark controller is in place. Also I believe any new plug wires are good but use resistor wires if you listen to the radio.
Old 09-02-2018, 12:53 PM
Noahs944
Noahs944's Avatar
I once found bad ign wires by fluke (pun not intended)
when the garage lights were off & it was dark, engine running & hood up.. I saw sparks on the wires.
Did you verify wire orientation is correct on cap?
Old 09-02-2018, 04:02 PM
Tom M'Guinn
Back in the olden days --think typewriters, phone booths, and record players-- it was a common shade-tree diagnostic technique to pop the hood in a dark garage and look for sparks. Unfortunately, with our turbo cars, the wires start to fail under heavy load first, and generally do just fine in a dark garage while idling and/or revving with no load. Spenc -- see my other post about Clewett wires. Perfect for MSD -- great value and great wires!
Quick Reply: Bucking under acceleration
