Stock Turbocharger variants?
Old 09-20-2018, 01:19 AM
Dubai944
Dubai944's Avatar
Default Stock Turbocharger variants?
Looking at a race category rule that allows any turbo, providing "the compressor housing inlet diameter is no larger than the original standard turbocharger compressor wheel inducer diameter plus 10%."
So which stock turbo of all the 944 and 968 variants had the biggest inlet diameter?
And when you add 10% to that, what are current options for most efficient turbo of that size?
Old 09-20-2018, 06:13 AM
333pg333
333pg333's Avatar
Thought you were going down a different path?
Apparently there have been some guys modifying stock turbos to great success.
Saw it on one of the FB pages though.
Old 09-20-2018, 08:42 AM
Dubai944
Dubai944's Avatar
Been down a few paths the last couple of years Pat...
I started building a motor for sports sedans but then got busy the last couple of years with work so put that on hold.... I bought another 944 road car and started modding that for targa events but haven't finished that...I have been close to buying a Radical in Dubai ....but now I am again looking at different options for possibly running the 944 next year now I finally have found some some time again to dust it off.
I suspect the turbo size restriction kills the possibility of building anything too exciting for prodsports - thus the questions, but its one possible option now I see they have relaxed some of the body and suspension mod rules for 2B.
Old 09-20-2018, 09:47 AM
Humboldtgrin
Humboldtgrin's Avatar
Does that mean you could essentially use a twin scroll turbo?
Old 09-20-2018, 12:54 PM
Paulyy
Professional Hoon
Paulyy's Avatar
The 968 turbo S and Turbo RS had a k27. im pretty sure it's a 2.5"
Old 09-20-2018, 02:27 PM
blade7
blade7's Avatar
Didn't it have a number 10 turbine housing? Pretty hard to find now apparently.
Old 09-20-2018, 07:35 PM
Dubai944
Dubai944's Avatar
Yes, but so far I can't find an accurate reference for the compressor inducer diameter used on the particular K27 version used on the 968. anyone know that? Seems like the K27 came in a lot of different versions and sizes. If you are right about 2.5inches thats 63mm which means you can go to any turbo with a 69mm inlet, which might mean you can make something work decently well on a 3l motor. But I thought the inlet was smaller than that.
Old 09-20-2018, 09:02 PM
rlm328
rlm328's Avatar
Inlet or compressor wheel.
Inlet is 2.75", Compressor wheel is 3.00"
Old 09-20-2018, 10:29 PM
Dubai944
Dubai944's Avatar
It's the compressor wheel inducer diameter we are after to base the calculations from.
Old 09-20-2018, 11:37 PM
rlm328
rlm328's Avatar
Here are the specs for the Borg Warner K27, if I am not mistaken I believe BW bought KKK a while back. The column titles make no sense.
Old 09-21-2018, 12:41 AM
Paulyy
Professional Hoon
Paulyy's Avatar
I would assume it would be closer to the 7006 size used on the 964 3.3L turbos. the 3.6L turbo used the 7200
7006 - IN 52.40mm EX 76mm from searching the net.
This is just assuming porsche would have used something they've already got laying around. maybe smaller turbine wheel.
Old 09-21-2018, 04:57 AM
Dubai944
Dubai944's Avatar
To be honest I am having a bit of trouble understanding the rule the way its written. If the "compressor housing inlet diameter" can't be bigger than 10% more than the original "compressor inducer diameter" then assuming the inducer is somewhere between 52 and 55mm, then the inlet of the biggest turbo allowed can be a maximum of 57-60mm.
What does that mean in real terms of available modern turbos and what could be achieved for torque and power on a 3 litre engine?
Old 09-21-2018, 11:24 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Is that the actual quote?
if that's the case, you'd want a custom turbo put together imo.
Old 09-21-2018, 01:02 PM
Paulyy
Professional Hoon
Paulyy's Avatar
I have been thinking about it. It doesn't make sense. With more modern turbos the inlet is much bigger than the inducer. so does that mean you have to down size turbos?
I'd be shooting them an email with further questions.
Quick Reply: Stock Turbocharger variants?
