Best Replacement for stock 951 injectors
Old 11-12-2018, 09:44 PM
davepnola
davepnola's Avatar
Default Best Replacement for stock 951 injectors
What's the best replacement injector for an 89 951 ... mods are Russel 951 Dme III chip , adjustable boost set at 15psi , webcam grind 270 I think , adjustable FPR set at 43lbs , stock hollow exhaust ... k&n air filter ....
I would like to replace with 3 or 4 hole injectors
Thanks in advance ....
Old 11-12-2018, 09:51 PM
V2Rocket
Rainman
V2Rocket's Avatar
You could buy my 4 (or 6? I don't remember) hole 72lb injectors for $100 shipped
You'd need to adjust your tune and add ballast resistors though.
Old 11-12-2018, 10:58 PM
davepnola
davepnola's Avatar
that might work what resistor works with them ?
Old 11-12-2018, 11:35 PM
V2Rocket
Rainman
V2Rocket's Avatar
these are 2.4-2.8ohm range, 951 ecu wants 5.5 or so.
Old 11-13-2018, 12:53 AM
Humboldtgrin
Humboldtgrin's Avatar
I thought the DME is looking for 2.25 or higher ohms? If I remember correctly Clark’s Garage has a write up about this. If the stock injectors are 4.5 ohms and it’s batch fire then two 4.5 ohm injectors drops to 2.25 ohms in batch fire at the DME. 2.4-2.8 ohm injectors in batch fire would be 1.2-1.4 ohms at the DME. If you add a one ohm resistor in series with the batch fire injector harness it would bring the ohms back up to 2.2-2.8 ohm range and not fry the injector drivers in the DME.
Old 11-13-2018, 12:12 PM
Willard Bridgham 3
Willard Bridgham 3's Avatar
I will support Jon Milledge on this: the stock injectors on the turbo are the best Motorsport injectors made, why do you want to change them?
Old 11-14-2018, 08:49 PM
davepnola
davepnola's Avatar
I thought the newer style , not the needle pin type were outdated compared the newer 3 or 4 hole injectors ?
what about theses compared to stock ? https://www.fiveomotorsport.com/a910...urbo-17104224/
Old 11-15-2018, 07:17 PM
davepnola
davepnola's Avatar
bump
Old 11-15-2018, 11:43 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Your question is kind of like asking what's the best pant size. It depends what size pants you need. If you put in bigger injectors without changing the tune/chips, it will just run poorly/rich. If you can adjust the tune for whatever injectors you buy, then your best injector will be one in its sweet spot for your power level. Theory aside, if you are still running the stock turbo, and don't plan to retune, then stock chips are what you want I'd say.
Old 11-16-2018, 12:15 AM
davepnola
davepnola's Avatar
would u say these are as close to stock besides being 3 hole instead of the needle type ? better technology
Old 11-17-2018, 12:12 PM
Raceboy
Raceboy's Avatar
Lol, they were perhaps 20 years ago, times have changed...
Quick Reply: Best Replacement for stock 951 injectors
