944 turbo starter upgrades
http://garage.ideola.com/prod-ElectricsUpgrades.html
I think this is the same one though it doesn't specifically say 944 turbo. https://www.pelicanparts.com/More_In...xoCv5sQAvD_BwE
Are these starters still available? I read somewhere he went out of business recently? I saw them on pelican parts but at a higher price as well.
I've been having a slow starting condition on my new engine, it has new everything and is still slow to start. I have the updated sensor bracket, new battery, starter, harnesses, grounds good, completely new dme harness. I've replaced about everything and the slow condition continues. I think the starter just doesn't get it moving quickly enough right off the bat so is takes a few more turns to get it up to speed to fire. I'm interested in these high torque starters and if they are worth the buy. Do these eliminate any interference issues that our cars are known for?
There are a bunch of forums regulars who have used the Hi-Torque IMI starter. The one your linked on Pelican is the IMI-155 which is at least the right model but unless is specifies which direction it turns (Clockwise or Counter-Clock) no way to be certain though since they list it for the 944 odds are that is the counter clockwise one.
A couple of older threads on the subject here:
https://rennlist.com/forums/944-turb...-on-951-a.html
https://rennlist.com/forums/944-turb...a-starter.html
Those are great starters and very well engineered using quality components, when they first came out on a group buy I bought one for all my cars and a spare (below).
However I don’t see how they will fix your issue, they may help idk, but it’s not a fix. There is something wrong somewhere as a regular starter doesn't normally produce a labored start like you describe. Have you done anything performance wise to your car? Raised the compression by skimming the head maybe?
Looking to sell that spare?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Maybe your stock starter is worn out or has corrosion on the contacts. While that aftermarket starter is a good part a stock starter will have no problem spinning over a healthy engine. The only reason that you woudl really need a more powerful starter is if you upped your compression ratio to 11:1 or higher!
Just randomly. I had a cold start this morning that took a little longer but the morning before on a cold start about the same time it started remarkably fast, faster than a blink of the eye. Outside temp has been about the same 70f. Warm or cold doesn't make a difference. I use a vitesse logger to verify all my sensors are getting normal readings and they seem to be.
It's brand new from the tank to the rail. Also I use the solid state dme relay with pump prime. It always has pressure when cranking, verified with a gauge.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
OK, sounds like we might be miscommunication here (standard internet procedure). Are you saying that it occasionally 'turns over' slowly or that it takes longer to fire up?
