brake rotor cooling vanes - direction?
Old 02-19-2004, 04:17 PM
roadrunner
roadrunner's Avatar
Default brake rotor cooling vanes - direction?
I replaced the front pads on my 89 951 and noticed the cooling vanes inside the rotor, from hub to outside edge, angled into the direction of rotation of the wheel. I was always under the impression that they should angle away to facilitate the air flowing outwards from the center. It also would seem to be this way in just about every picture of race cars that I've ever seen. What have you seen on your cars?
Old 02-19-2004, 05:10 PM
Sam Lin
Sam Lin's Avatar
They need to be angled so they'd scoop air into the center of the wheel if the car was going BACKWARDS.
Sam
Old 02-19-2004, 05:48 PM
facboy
facboy's Avatar
eh? i don't get that Sam.
Old 02-19-2004, 06:14 PM
Sami951
Sami951's Avatar
Huh? The rotors are identical left/right (right?), so if the vanes are directional, the other one would be going the wrong way... looking at the ones I have right here, the vanes are actually pointing straight towards the center, not slanted either way. '86 951 so the rotor is not same as in your car though.
Old 02-19-2004, 06:53 PM
jerome951
jerome951's Avatar
Sami, the TurboS cars use different left and right rotors. The vanes are curved, not straight as in the earlier cars.
The vanes should run so that as the wheel turns forward, it should pull air from the center and expell it at the edges. If it is scooping air from the perimeter, it is mounted backwards.
When I bought my car ('89), the PO had the same direction rotor on both sides. The rotor that was set up incorrectly cracked significantly more than the proper rotor after hard track use. Then it warped...
Old 02-19-2004, 07:38 PM
Sami951
Sami951's Avatar
Jerome, excellent info (and all new to me!), thanks!
Quick Reply: brake rotor cooling vanes - direction?
