Lower BS cover reseal writeup
Old 06-04-2020, 01:22 AM
moalaska
moalaska's Avatar
Default Lower BS cover reseal writeup
I decided to do a comprehensive writeup on how to reseal the lower balance shaft cover.
1. Clean outer mating surfaces with degreaser and brakleen, make sure to get some in your eyes.
2. Put on some rubber gloves
3. Get some hondabond 4 or yamabond
4. Smear sealant liberally around outer housing and especially rear plug.
5. Wait for rennlisters to tell you this is an abomination and you should have just taken the 15 extra steps to remove the cover and do it properly, just to have it leak again in a year.
6. See attached pictures.
Old 06-04-2020, 01:35 AM
dme
dme's Avatar
I don't think it is too rare to see others seal the rear plug that way.
You know, "This is only temporary unless it works."
Old 06-04-2020, 07:57 AM
MAGK944
MAGK944's Avatar
Someone on this forum makes replacement seals out of DuPont Viton, same material as the valve stem seals which imo is what Porsche should have made them from. I have them of all my cars and they provide a more permanent solution.
Old 06-04-2020, 11:58 AM
jimbo1111
jimbo1111's Avatar
I love simple solutions. Let us know if it holds up.
Old 06-04-2020, 01:43 PM
Tom M'Guinn
Tom M'Guinn's Avatar
This is an abomination and you should have just taken the 15 extra steps to remove the cover and do it properly, just to have it leak again in a year.
What goes around comes around:
https://rennlist.com/forums/924-931-...rear-seal.html
Unfortunately, your motor is sure to have a terrible oil leak. I'd recommend an oil pan.
Old 06-04-2020, 01:53 PM
moalaska
moalaska's Avatar
Been running without an oil pan for years,too much work to put one on.
Old 06-04-2020, 02:21 PM
Tom M'Guinn
Another weight-saving secret!
Actually, it's a century old idea....
Old 06-04-2020, 05:32 PM
Scott H
Scott H's Avatar
Just cut the oil pick up tube and run some hose from it to a drum of oil in the car, voila, instant dry sump.
Old 01-03-2021, 07:01 PM
Doyle623
Doyle623's Avatar
I remember reading about someone making upgraded rear balance shaft seals, but can't seem to find anything on them. Any additional info/links on these would be greatly appreciated...
Old 01-03-2021, 08:54 PM
MAGK944
MAGK944's Avatar
It was @Voith on this forum that organized the Viton balance shaft seals. I don’t know if he still does but I’ve tagged him, and he is pretty active here, so maybe he will chirp in on this post.
Old 01-03-2021, 10:59 PM
Scott H
Scott H's Avatar
So long as it's a standard size o-ring you should be able to order some up from McMaster or MSC. If I didn't just move I could have grabbed one to measure or checked notes on my PC but I don't really have access to either right now. Pretty sure the size is listed on PET, or search the part number on google.
Old 01-03-2021, 11:28 PM
MAGK944
MAGK944's Avatar
Its not an o-ring, it’s a seal. The custom replacement made of Viton looks like this.
Old 01-04-2021, 07:53 AM
Voith
Voith's Avatar
It is probably the worst oil leak design flaw on 944 engines, I've had few seal experts thinker with covers of old and new version of engines, and this is what they came up with. I still have few of each if anyone needs a pair.
https://rennlist.com/forums/924-931-...-end-seal.html
Old 01-04-2021, 01:57 PM
Doyle623
Doyle623's Avatar
Thanks, Voith, PM sent.
Quick Reply: Lower BS cover reseal writeup
