3L power limit
3L power limit
How much power could this setup make if I were to upgrade the turbo?
3.0 Liter
JE Pistons
Pauter Rods
Extrude Honed Intake & Head
O-Ringed Head and Block
·Raceware Studs
Millege Hybrid Turbo
Hi Performance Cam
3.0 Liter
JE Pistons
Pauter Rods
·Raceware Studs
Hi Performance Cam
Jay Wellwood (06-08-2021)
These don't really add power, they just fit the application or assist in bringing rpms faster, unless you are changing compression ratio:
JE Pistons
Pauter Rods
This is just used if boost exceeds the oem gasket (spec'd for 17 psi|) so can improve reliability on high boost:
·Raceware Studs
Regarding the Cam & turbo, would you be more specific?
JE Pistons
Pauter Rods
·Raceware Studs
I did 418hp to the wheels on an outdated piggyback on my 3.0L at 15 pounds boost.
New turbo great but get proper engine management with it or Vitesse Maf at least with any upgrades.
This is a great deal if you dont have the engine management
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/1220686-fs-electromotive-tecgt-standalone-ems.html
Noahs944 (06-07-2021)
Warrentdo (06-21-2021)
Pump gas, 300-350whp 15ps boost is probably in the ballpark for the engine to last. As you turn the boost up your head gasket life shortens and you need something to keep from detonating. Over 400hp the life of everything gets really short. There are people who get more out of them but not many.
fejjj (06-20-2021)
