Vitesse Stage 2 kit
Vitesse Stage 2 kit
I bought a second hand Vitesse stg. 2 maf/turbo kit. I was hopiing I could get the wiring details from someone here who has installed one before back in the day. Admittedly I dont know much about this kind of thing. I have a wiring diagram from PerfectPower, but is this the computer that Vitesse used for their kits? I did try to contact Vitesse and they said they no longer support this kit because it is outdated. Thanks for any help.
I bought my Vitesse kit secondhand in like 2008 and was told support only extends to the original purchaser so I was on my own. The dude wouldn't even tell me where he prefers we source 12v power for the MAF. (Protip- There is 12V available at the cycling valve plug which is surely deleted on any 951 at this point).It's been 14 years and I still have no idea what any of the switches on the chipboard do
If the product wasn't so good I would have tossed it due to the lack of support - but once its set up it just works...so I still run it.
Next time I pop by the garage I'll draw up a diagram for you
Mike G.
That would be so helpful! Even some detailed pics would go a long way. Thanks man!
For sure - you will absolutely love the way the car drives with the Vitesse kit. I literally had Toyota like drivability and reliability once I had good grounds (iceShark may he RIP) , new engine harness (thanks to LR) , and the Vitesse hardware/software. I put around 200K miles on my 951 so far under my ownership with at least 180K of those miles with the Vitesse Racing stuff on it and never had an issue with it once installed and sorted.
notnilc20 (04-19-2022)
I had talked with John about mine that I got with the car when I bought it. He did point me to this doc. I don't know if it will help or not:https://ln5.sync.com/dl/1bb19c8b0/qz...8njeh-jvupj95c
notnilc20 (04-20-2022)
OP - based on the pictures you sent, you do not have a "Stage 2 kit". Some of your parts date back to 2003. You have a S2 turbo from 2006-2007, and you are the 4th owner if not the 5th.
The particular PB you have was discontinued back in 2004.
As I told you (as well as the seller of your parts), the instructions were unique to the PB you have and were lost (due to HW crash) years ago. So be careful which wiring diagram you follow.
Based on the pictures I have seen, you have a plug-and-play MAF pigtail, so no wiring (except for switched +12V).
Having 1000s of items in the field, in many cases some exchanged hands numerous times. Not knowing the condition of the parts, and considering the number of owners, no one including us can offer free support over and over again.
Over the years, when possible, we always helped non original owners.
As for the dip switches on the ChipBoard, they are used to select different images. We do not keep track of this information. We always ask the original owner to keep track of it!!!!!
As everyone can tell from the above posts, Vitesse products are well designed and well built. People are still using them 20+ years later. The support policy is in place for a reason! So when buying used, make sure you get everything, including the instructions we originally provided.
Some installation instructions were unique!!! There are various PB models as well as MAF styles, not to mention software releases. Each installation document is unique to the hardware you have. Using incorrect instructions could damage your HW.
Notny41, I know you are trying to help the OP, and it's appreciated! However, this is the perfect example of a hardware, software and instructions mismatch.
Once I figured what "you" have, I was able to send you the proper instructions.
The installation posted here, is not compatible with every MAFs. The hardware is totally different.
We are fortunate to have John a part of this community.
wiring
The maf connector and temp sensor look to be plug and play as you mentioned, just need to find a good 12v source.
Looking at the wiring for the PB, I see a purple/blk, grey, and blk wire used to connect to the serial port with a USB connector to wire to a laptop.
Blk/wht, green/yellow and green all connected to a single green wire
A yellow, purple and brown/blk wire.
brown soldered to a blue wire.
red and blk wire I'm assuming for power and ground
And the seller also threw in an extra harness that he said wasn't really connected to anything but was told that it was for if you wanted to run a wasted spark application. ???
Finally I have a screenshot of a wiring diagram from perfect power. This was supplied by the seller. Is this a smt6 box? It seems that not all the wiring is there in the diagram however.
Again,I appreciate any help provided. Thanks in advance.
The mystery harness for wasted spark application?
OP...with all due respect...
How much work have you done on your car previously? Are you comfortable doing this install?
If you are not, this may not be a good project for you to take on.
Do you plan on installing the turbo yourself? Or do you have a tech who will do the job?
Neither the turbo install or wiring at the DME are for the faint of heart. . Ask me how I know.
20 years I've been working on my 951, stuff still goes wrong for me messing with the DME harness.
Just my 2 cents, I don't want to be negative, everyone has to learn somehow, but will be an intense project.
You may want to consider a new air filter on that MAF too.
Neither the turbo install or wiring at the DME are not for the faint of heart. . Ask me how I know.
Good deal.
I'm sure that IMS project is quite an undertaking!
May want to consider re selling what you bought,
the current Vitesse MAF kit would get you close enough that you *might* not even need a PB.
Do a search for V-MAF+
Keep that harness intact, if you can!
And if you insist on installing a PB, the SMT-8 is more current technology than the 6.
I've been super busy but I plan on being at the garage tomorrow morning and I'll shoot you some pictures. My recollection is you plug the MAF adapter harness into the AFM plug, source 12v from the cycling valve connector, and find a good ground. Thats all for the MAF.
I don't think you'll need the piggyback - it is incredibly close right out of the box and in 14 years and 180K miles I haven't felt the need to adjust anything. Perfect AFRs, idle, etc.
