Turbocharger assessment
Greetings to all fonts of wisdom 951 related...
As Newbies to both engine rebuilding and the 944 T itself, we are rebuilding the engine of a 1986 model with a bad #2 conrod bearing. While we have every thing apart, we want to make sure we get all of the bits and pieces sorted out before putting it back together again..
Objective is to have the rebuilt engine/car as reliable as possible for fun road use, and if cheap gains to HP and performance can be achieved without breaking the bank, so much the better.
Can you point us to any procedures in addition to the Workshop manual for evaluating the condition of the Turbocharger (k26-6) and its seals while out of the car and whether or not a rebuild is advisable? The car previously tended to burn oil, but we are not sure one could specifically point to the TC as the culprit.
Much obliged for any guidance provided
B&L
B&L
Last edited by brocknlucas; 01-17-2023 at 09:25 PM. Reason: specified turbo number...
My two cents as a former newbie ‘86 951 owner (who still has a lot left to learn)...
The turbo on a 951 is a bit of a headache to get to. I think there’s a lot of value to doing all of the “while you are in there” things that you can on a now 37-year-old car.
If you don’t know the history and don’t have tons of experience... send the turbo out to be rebuilt while you’ve got everything apart.
Send it to Charlie at Evergreen Turbo and be done with it. Will give you honest opinion and provide upgrade ideas. Look up Evergreen here on Rennlist, plenty of recommendations.
spencang (01-18-2023)
I sent my turbo to Evergreen as I was having an oil blow by issue, Turns out my turbo was fine but I did some upgrades. These older turbos benefit greatly by doing updates to the impeller wheel. My 951 went from zero to full boost at 4k RPM on the old turbo, to boosting linearly starting from 2.8k. Also I can only turn my boost control up to 45% or so and I'm getting the full 17-18PSI, It's been an amazing upgrade and I'd do it again.
These cars are plenty fun even in stock form. My best advice is too upkeep them in there best original form. Maybe a chip upgrade with some additional boost helps a lot in the fun department. At most a very fun turbo upgrade like Evergreen. But, even that turbo will overcome the shortfalls of the DME electronics ability to read hp past 300 hp.
There are lots of resources to keep these cars running forever. You have Koons wiring harnesses, Ftech 9 for DME's. KEP for beefer clutch etc. Electronics are aging and this is probably the best investment one can make.
Unfortunately the DME electronics aren't that easy to overcome for added HP and have been fiddled with by numerous hp chasers with limited success. So for me at least, I feel that, if you want to chase big HP, I think its best to go all out and start with a stand alone.
