Non MO30 front brake caliper/disc options?
Original caliper refurbs in the UK seem to running at $1000+ in the UK, if some new pistons are required. So what options are there to use a later cheap Porsche caliper/disc/adapter while also fitting something bigger/better. I'm already using 18" wheels.
9products sells adapters to let you swap to either Big Red or up to 996 TT/GT2 calipers.
https://www.9products.com/category/1305/series-944
Can't recommend 9p as a seller, they're horrid for responding and horrid for honest inventory. Only sharing their link because it shows the products.
Duke and Pete zh in Europe make and sell the same (I believe whoever Duke worked with was actually the first to make these, 9p then copied them).
blade7 (02-16-2023)
Thanks for the reply. I did a search on here and found info about using relatively cheap 330 or 350mm Cayenne discs with centering rings. Lindsey are selling a "big red look caliper" in their budget brake kits, so there's obviously a fairly cheap caliper already out there somewhere?
Pretty sure we have the Touareg here, Do you know if there's an adapter to bolt either of those calipers to a late 944 turbo?
Blade , $400 dollars for used Audi S8 D2 calipers on us ebay , most do not have the corrosion issues we suffer from ,which are basically F50 calipers . Get some centering rings from Superman on this forum and use either 330mm or 350mm cayanne disc which are dirt cheap , £45 each or something . I had the adapters made up by Freaky Parts in uk .
I also used 750 BMW master cylinder and brake bias valve.
Hello mate, I couldn't see any of the S8 calipers on UK ebay, and when I contacted freaky parts about the adapters they were quite vague about them. I think they wanted to see the car too.
I tend to find it better to purchase from our cousins due to the more favorable weather conditions and the parts are in much better condition as a consequence so what you pay in tax you save on refurb costs
. Here's one ad of many showing whats available (hope this doesnt break any rules , just a representation ) .
Im surprised freaky parts do not still have a drawing . I had to send spindle , caliper and disc to them but any good local machine shop should be able to sort it . Think I paid about £300 for adapters .
I got my knock-off "Big Reds" from here: https://www.design911.com/p/brake-ca...93--designtek/ Same ones that Lindsey Racing sells. I haven't installed them yet but the quality seems good.
I got adapters from Lindsey Racing for 330mm rotors, either 996TT or Cayenne rotors.
blade7 (02-16-2023)
I was hoping to have my conversion done by August but doesn't look like that's going to happen now. This is incredibly frustrating and I'm surprised that there aren't more suppliers offering adapters for this upgrade as opposed to the unreasonably expensive Big Red upgrade.
I had to cancel my order my order with 9products and and order their parts though Design911, they are useless at sending orders.
If you want to stick with M030, 993 C2 front calipers are a direct swap, I picked up some cheaper than any of the 944/928 calipers I could find.
