Broken Exhaust Studs
Old 03-28-2023, 06:56 PM
vaportrail
vaportrail's Avatar
Default Broken Exhaust Studs
After a fun project of replacing a leaking oil housing, we replaced all the exhaust studs (of course). Everything was torqued according to factory spec, with a high quality torque wrench.
While idling in the garage - two of the studs snapped, closest to the firewall. Photos below.
I ordered the studs from 944Online, who we've had excellent luck with: https://www.ebay.com/itm/393025803235
On hindsight, I would have upgraded the studs. I have now ordered OEM.
Does anyone have experience with this?
Old 03-28-2023, 08:58 PM
ElRicardo
ElRicardo's Avatar
I have snapped a couple of the original studs off. Both were the bottom most studs on an S2, one being the dreaded aft stud of cylinder 2 that can’t really be attacked because of the curvature of the manifold. Ultimately I took the head off, which is a bold task on the S2. But once the head was off I was able to back the broken studs out with careful application of a small pick and a tap hammer. Easy, only took 3 minutes (not counting the 2 hours to get the head off and 2 hours to put it back on, plus the oil and coolant mess. Possibly the worst “time to get at versus the time to fix” repair I have done on an 944. Except maybe replacing the steering shaft on my turbo. That one might be worse… yep, it’s worse.
Old 03-31-2023, 09:06 PM
dme
dme's Avatar
Makes you wonder how long the rest of those studs are going to last. Did you order eight new studs as opposed to just the two broken?
Old 04-01-2023, 09:25 PM
gpr8er
gpr8er's Avatar
FYI fellas the allen head intake bolts are the perfect size and length for the exhaust studs. Pull the studs and replace with the German hardware. Butter them up with anti seize and it makes it so much easier when you have to remove the headers never have to fight getting around the studs when removing the headers.
Old 04-05-2023, 02:52 PM
vaportrail
vaportrail's Avatar
An update - after being told by a machine shop to remove the head to pull a broken stud, a neighbor recommended a metal fab shop to weld a nut on what little of the broken stud was left.
I was skeptical but rented a u-haul trailer to haul the 944 to the shop. 15 minutes later the broken stud was out.
Old 04-02-2024, 09:51 AM
ecrouch01
ecrouch01's Avatar
I had the same thing happen to me with the 944online “studs”. I love 944online and their customer service is unmatched. However the kits for the exhaust studs is poor as they are actually low grade set screws, not “studs”. Studs are almost always stronger inYield strength.
Long story short, after the second stud broke I pulled the headers off and am now waiting for the Rennbay billet stainless exhaust studs. These are stainless so I can only assume they won’t be as strong as stock steel studs, but I’m going to give them a try.
Old 04-02-2024, 12:58 PM
V2Rocket
Rainman
V2Rocket's Avatar
I have *never* had a factory stud break or fail on me.
I have had several of the aftermarket stainless/copper nut kits fail even during initial installation. Pure garbage.
CHD (04-03-2024)
Old 04-02-2024, 02:24 PM
ecrouch01
ecrouch01's Avatar
V2, yeah just did some more research and with you your input decided to ditch the stainless studs and get the factory studs, straight from the dealer. It is a guarantee that stainless steel will be weaker than the stock studs. Also, at 7$ a piece I think the factory studs are made of a specific material to cope with the heat and thermal expansion. Porsche engineers know their stuff!!!
It is also worth noting that the stainless studs may corrode to the aluminum and make them HARDER to remove than the stock steel studs with antisieze
Old 04-02-2024, 02:36 PM
V2Rocket
Rainman
V2Rocket's Avatar
In this case I don't think its a metallurgy thing - I think the stud kits sold by 944 vendors are just very low quality.
If you came up with your own SS studs/copper nuts from a fastener store you could probably do fine.
Old 04-03-2024, 06:50 PM
931guru
931guru's Avatar
Stainless Steel Studs (with 4 mm allen head), M8 x 1.25 x 30 mm long, 68 cents each. Eight is less than $6.
https://belmetric.com/m8-stainless-a...u=SS8X30FLATSS
Old 04-03-2024, 08:19 PM
944M3
944M3's Avatar
Thought it was just me, but I’ve also had aftermarket exhaust studs snap from 944online.
Old 04-05-2024, 04:49 PM
Golden Hands
Golden Hands's Avatar
Maybe a little bit pricy. And they might not even be good for exhaust hardware as the exact material is not stated. I just felt like posting something.
ARP Accessory Studs
Just called ARP. Theses bolts are great for exhaust as the material is Stainless 450.
Carpenter Custom 450
Mike G.
Old 04-09-2024, 06:43 PM
ecrouch01
ecrouch01's Avatar
Just got the Porsche OEM studs and nuts installed. Studs appeared to be a soft steel with zinc plating. Nuts looked to be stainless lock nuts but they could have been inconel? Anyways each stud was 8$ and each nut was 11$ without the discount. In total added up to be about 150$
I’ll keep you all posted how long these last without cracking, hope it’s forever! However I still recommend factory hardware for the exhaust manifold.
Old 04-09-2024, 06:46 PM
944M3
944M3's Avatar
Ouch
Old 04-09-2024, 06:48 PM
ecrouch01
ecrouch01's Avatar
Haha ouch is right. Not the mention how much of a PITA installing the headers is!! I mean so much prying and wedging to get them to line up
Quick Reply: Broken Exhaust Studs
