Running 9 inch CS wheel up front and back
Are you saying Porsche set up the 86 944 turbo to understeer? And European E36 M3's, that incidentally came with much higher outputs than US cars, didn't come with a square setup.
As stated in my previous post, a square wheel and tire configuration is not the be all, end all in chassis setup, but is an easy way to tip the balance, which is why so many track enthusiasts with front engine/RWD cars go to it, and conversely, why so many OEs still use staggered setups even in the era of sophisticated stability control systems and driver aids.
Another good reason for a square setup is wheels/tires can easily be rotated/flipped to maximize their lifespan, assuming that wheel offsets are same front to rear.
Seems to be some different opinions on that thread, is going wide on the front a short cut, instead of a better front suspension setup? I had an Audi A4 quattro with a square setup, that was easy to control in 4 wheel slides, in the wet, but the front pushed in the dry. I now have a SEAT Cupra R AWD that came from the factory with 2 degrees negative camber all round, and a square setup. And it doesn't understeer anything like as much.
It's hard to know. We can only guess. They were so rear engine centric that perhaps they just assumed to use a wider rear than front? Perhaps less sophisticated damping was available back then and a square setup with quite a lot of negative camber tramlined too much for them? At normal road speeds it wouldn't matter so much. At high speeds and on the track, there's too many people that have run successfully with a square setup for it to be just subjective.
I think it's over simplifying it to say that Porsche with all their resources, couldn't work out the best way to set up their competition cars. Perhaps they decided the extra weight of the wider front wheels and tyres wasn't worth the trade off, when they could control understeer with camber, anti roll bar and damper set up. And perhaps it's all the drivers that run wider front wheels and tyres that are cutting corners on setup.
Perhaps perhaps perhaps...We'll never know. But remember, the factory also said not to go over what, 16" wheels? Clearly 18" wheels work fine despite the extra unsprung weight with bigger wheels, rubber and braking systems. Also, despite the factory homologating the 968 t RS were they really serious about that car? Many compromises were allowed. Namely 8v engine. By that stage they could have explored and developed the 16v turbo for much greater results. (Would have rendered obsolete many a thread in the forums too). It would seem that they had no real ambitions for that car vs 911 or prototype based models. The Carrera RS was the preferred option for the race teams too. As for cutting corners with the sqr setup (pun intended?) alluding to some perceived lazyness, I think you're off the mark there. I can only speak for myself but I know what we went through to improve my car back then. If the sqr setup showed an immediate improvement then so be it. Isn't the idea of racing to decrease one's lap times?
The following 2 users liked this post by 333pg333:
DasSilberWedge (10-09-2023),
Droops83 (07-24-2023)
Yes the pun was intended . I could mention that there were optional extra 18" road wheels for the 968. And Porsche were probably serious about the 16v 924 LeMans cars that didn't run a square setup AFAIK. I think the 968 S/RS came with a pretty serious price tag too. But anyway, 15 years ago when I put KW's on my turbo, I used some 968 track day settings for the bump and rebound, and had the geo set up by one of the best guys in the country. Combined with good tyres, it's pretty neutral if it does slide, though my Mrs isn't a fan of the ride on bumpy roads, and wont get in the car. So I think for a road car at least, square is just playing at Race car.
Of the 24k miles that I've done in my turbo, on the KW's and 18" wheels, at least 23k of those have been done on the same 100 mile back road route. It's a great route that a bike and a car magazine used to use for their road tests. I've also done over 40k miles down there on bikes over the last 30 years. Track day KW settings on that road are fine. Perhaps you have better roads over there, because I've driven on roads here that made the ride very uncomfortable.
Whether a wheel fits depends on how much negative camber you want to run.
Even though common knowledge says it wont fit, its easily possible to run early offset wheels on a late offset car for instance... if one runs enough negative camber (in this case around -2 degrees which also gives some very good performance benefits).
That said, I think the 9 inch rears should easily fit the front
