Anyway to seal a leaking Turbo Coolant pump?
Old 02-07-2005, 06:33 PM
sm
sm's Avatar
Default Anyway to seal a leaking Turbo Coolant pump?
My turbo coolant pump is leaking, but otherwise works fine. Has anyone tried to seak these puppies up, with JB Weld or something similar?
Thanks.
Old 02-07-2005, 06:42 PM
Charlotte944
Charlotte944's Avatar
If its leaking, its toast.
I've torn one apart, and there are no "user serviceable" parts.
Sorry.
jerome951
jerome951's Avatar
They aren't rebuildable, so I don't think you could harm it any further by trying JB Weld or something similar.
Old 02-07-2005, 06:46 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
Sounds like a job for duct tape!
Old 02-07-2005, 06:54 PM
Zero10
Zero10's Avatar
Why not pop it open and try?...
Where is it leaking from?
Old 02-07-2005, 06:59 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
Hmmm...we think my dad's is leaking either from the turbo water pump or the turbo itself...
Old 02-07-2005, 07:29 PM
Peckster
Peckster's Avatar
Oh yeah, JB Weld is just the stuff to fix something like this. Not! JB Weld is crap.
Old 02-07-2005, 07:30 PM
Matt H
Matt H's Avatar
I have a used one for sale, wasnt leaking and worked well when removed. PM me an offer.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 02-07-2005, 09:14 PM
Claus Groth
Claus Groth's Avatar
When mine leaked, I removed it and found that the bent-over tabs that hold the motor to the pump had worked loose. I tightened them and the pump ran fine until it siezed after a month or two. I don't know if there was a relationship between repair and failure or whether it was coincidental.
Old 02-07-2005, 09:22 PM
theedge
theedge's Avatar
I resealed mine, works just fine. It was leaking from where the two plastic housings mate together. Its just screwed together. I used Ultra Grey RTV.
Old 02-11-2005, 07:17 AM
Luis de Prat
Luis de Prat's Avatar
I opened mine up where the two plastic housings mate together and found a rubber gasket that dropped right out. Wouldn't replacing the gasket suffice?
Mine was working just fine with only 65K miles on it, but it was leaking from where this gasket should seal the plastic housings.
From the way it's designed, I believe the coolant only circulates inside these housings, and not upwards past the impeller and electric motor.
Old 02-11-2005, 10:21 AM
Charlotte944
Luis:
I've torn one completely down, and even if you could replace the pump housing seal, you cannot get the shaft seals.
In my case the upper drive shaft seal was leaking coolant into the motor housing.
I have a new pump which I plan to install in the next couple of days.
Old 02-11-2005, 11:00 AM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Luis: You posted before regarding replacing the pump, you also mentioned it costed a total of Euro 135???
Old 02-11-2005, 12:57 PM
Luis de Prat
Yes, I have already bought and replaced the pump with the updated 951.606.130.01 unit, which supersedes the original pump and appears to be more heavy duty. Dealer price here in Spain is €129 plus tax. Final price for me was €135.
Before tossing my old pump out, I took it apart and thought that it might be repairable, but from what Charlotte944 says, I guess not!
Old 02-11-2005, 01:00 PM
hosrom_951
hosrom_951's Avatar
Euro 135 is an extremely good price IIRC, the cheapest i saw now runs at over US$200+
Quick Reply: Anyway to seal a leaking Turbo Coolant pump?
