i have no idle screw!
I never notice, anyway
mikeaagesen from here on the board was over at my place today as i was doing my vacuum lines, and we noticed that i have no idle screw - i just have a rubber plug in its place. now that i have replaced all my vacuum lines, could that cause a problem? what are the consequences of not having any air coming in thru the throttle screw?
Somebody probably adjusted your idle with the throttle stop screw instead of the idle control screw. If you can not get the car to almost turn off when you turn the idle screw all the way in the butterfly in the throttle body is probably open to far and will need to be adjusted.
