Testing blow off valve
I have noticed recently that my boost is not quite where is used to be running my APE II chips. Normally I see around 1.8 bar and now I am seeing around 1.6 bar on my stock guage. I read somewhere that if you take off the blow off valve and blow into either of the large inlets that air should not come out. Is this true?
Blowing into the bottom inlet pipe, I could not hear any air coming out. Blowing into the side inlet pipe, some air came out the top small hole.
Is this a valid test?
Thanks,
R.B.
Thanks,
R.B.
Just put a 12" piece of vacuum line on the nipple & suck on it: if zero resistance (keep sucking, never builds up vacuum, nice oily taste , then the valve is shot. If you can actuate the valve with vacuum & vacuum increases, then its' good.
Mark.
Mark.
Hey Man
Mark.
Mark.
yuck.. I would save my self the pain and jsut get an aftermarket recirculating valve.. those stock ones are junk..
the Turbo XS one they make for VW's is a prefect fit (in case anyone is interested)..
Originally Posted by KuHL 951
Ordered the EVO Diverter Valve from Paragon. The OEM, even the 'upgraded' 993 TT they sell now only lasted me a year. This is one part that benefits from aftermarket design.
Evo is the one I hear the most about.
I have this one with a MAF and it makes that sweet BOV sound.
(it is pretty big, and needs some modification of the lines to get it to fit under the hood, their other models might fit no problem)
of course I got that sweet sound with the 993 OEM BOV as well.
Just to update, I received my new blow off valve (EVO) and before installing it I wanted to test it. Blowing into the 2 large inlets and both were sealed. However sucking on the small inlet, I still did not get any vacuum built up. I installed the new BOV and took it for a test run. Still no difference in the boost (1.6 - 1.7 bar on stock guage 3rd gear WOT)
R.B.
R.B.
RB
If you are using CV and stock WG boost is set at 12 psi or so, drops off at higher boost to 9 psi or so.
In most cases stock WG spring gets weak with time.
A good Tial WG will fix that with MBC.
Defending the Border
Rest In Peace
Rest In Peace
Mark is dead on-
The BOV is one of the first things I checked when I bought mine, and sure enough it was shot. The turbo is "on or off", very brief transition period. Winter driving back from Wisconnsin was a real trick!
