What affect does MAF have on Spool up
#46
http://www.928motorsports.com/parts/...aft_keyset.php
#47
If everything mechanical checks out I would suggest you pull the turbo out and check the size of the hot-side wheel you have installed. Most 944 tuners Ive seen usually install a t4 wheel in an 8 housing. Make sure the wheel is no greater than a stage 3 t4. If they installed a stage 5 the difference can be as much as 700 rpm in spool times.
#48
#49
Pauly is correct - the turbo will spool a little quicker with the MAF, but a big difference with the MAF isn't so much at peak power, but everywhere else. Dyno testing, we would see about 15% gain at ~1-2psi of boost (M-Tune vs A-Tune).
You could also try advancing your cam a few degrees. That will pick-up lower RPM hp & tq.
It worked so well on my NA, that I went and advanced the cam in my 951 ~3°. Definitely a noticeable difference on spool-up and power driving around.
#51
Small Business Partner
But you could use an offset key correct from 928 Motorsports.
FQS switch can adjust ignition timing. I am talking about camshaft timing - two separate things on the 951/944.
By adjusting cam timing, you adjust when the intake & exhaust valves physically open & close in relation to the crankshaft angle. By closing the intake valves earlier (advancing the cam), it helps build dynamic cylinder pressure earlier in the RPM making more tq/hp. Additionally, it opens the exhaust valves slightly sooner - giving more exhaust energy to help spool up the turbo.
