17mm Hex
17mm Hex
Can someone tell me where is a good place to get a 17mm hex for the trans fill and drain plugs? Every place I call only goes up to 10mm.
Sears carries them as well, sold individually.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Or just take a bolt with a 17mm head and insert it in the hex hole and put a nut on the bolt to turn the plug out. Works well and its pretty darn cheap!
Chris White
Chris White
You can make your own tool. Get a short metic bolt and a couple of nuts which all take
a 17mm wrench. Stack the nuts and tighten down real hard to lock them all together. It works best if you want plug weld the nut at the end. Sometimes just tightening them will not be
enough on a real tight plug.
Wes.
Wes.
Chris White
Chris White
Also, if you have an air-cooled VW shop in town, they usually sell them too...
Thanks for all the suggestions. I think I may try it the DIY way first. Wish I had thought of that! Sears Hardware, Harbor Freight, Home Depot, Lowes, and NAPA around here only carry up to 10mm. If DIY doesn't look like it will work, I guess I will have to try Snap On or maybe Grainger?
