The MegaSquirt Thread (pics)
#226
Originally Posted by sharky47
I am really ready to purhcase one, probably after I get back from my mini-vacation. Can you use the MS to just handle fuel without any problem in the 944? I will be using the MS in a NA application for my track car, if it works out then I may start updating all our 944's with it.........
I really am curious to see how that PIC controller works out for you, do you have it yet?
No I dont have it yet, hopefully wont take too long to get my hands on it. I have the parts for some other circuits too, just gotta try them all out.
#227
I'm going to be trying to get mine up and running with just fuel in the next couple weeks. Right now I have link MAP kit and I'm looking to basically swap in the MSII. I'll be sure to document the install and any problems I have.
#229
Set to Full-Auto
Looks like my buddy is going to jump on board and convert his 924 from that peice of crap CIS system to MS, that should solve alot of his problems.
#231
Set to Full-Auto
Well, we are both techno-nerds - so it should be fun to fiddle with the settings via laptop, and it's not terrible expensive.
Also, I am a CNC machinist - so let me know if I can help with parts........
#233
#234
Originally Posted by Barry Johnson
Hey, did anyone ever get a solution to the missing tooth flywheel pickup problem?
#237
I saw some of you guys weren't even heard of MS, but Im going to use even better thing on my 931 (already purchased), and it's actually a Megasquirt spin-off. http://megasquirtavr.sourceforge.net...tro.About.html
I bought an assembled unit with LCD and already installed a unit like that to one non-Porsche (Audi).
#240
Why dont you use the ecu out of a Pontiac sunbird turbo. Its the same Ecu out of the Gm Typhoon and Syclone: 3 bar map sensor, Pulls timing under boost, wastegate control, can be tuned on the go, and this computer can be had for $45 in a junk yard or $60 on ebay. You may have to use some gm sensors but this computer has been hack, tweak and torn apart bit by bit and it pretty darn good. i'm using this on my 79 928 turbo. The things that i see having to be swap is a 2 watt 1% resistors from mouser electroincs for low ohm injectors. Gonna use it first to pull my timing under boost with the cis still in place 12 psi fully tuned i'm gonna see 22 psi muhahaha
