Which wires do I tap into for ignition and intrument lights?
I put in my A-pillar gauge pod with the Innovate wideband analog gauge and Autometer Sport Comp boost gauge today. Which wire do I tap into for instrument lights and which wire for switched ignition? Can I tap into the same ignition wire for the analog gauge and the LM-1 itself? I've been switching the LM-1 off and on manually as I have it powered by a wire to the battery. I've forgotten to turn it off or on several times and I don't want to hurt the O2 sensor. Thanks.
Arne.
Arne.
Campeck Rulez
you can tap off the little light behind the center vent for lighting. thats the closest light i can think of that dims with the lights. unless you can tap right off the dimmer. which is even closer. check the voltages at the light and see if they match the dimmer. (they should) and then you can tap off it.
switched power? i believe the headlight **** has a switched wire or two going into it.
ohmmeters are very handy
