Temp Gauge & Boost Gauge
Old 10-18-2005, 08:08 PM
promax_motorsport
promax_motorsport's Avatar
Default Temp Gauge & Boost Gauge
Hi All,
My temp gauge starts off reading fine and moves up about 40% of the way. Suddenly it stands to full attention (i.e. rises to the top of it's deflection). It then remains there (happens after about 10 mins) until switch off.
Engine temps are fine - just the gauge itself. Has done this for at least 4 years according to car's history (it's a 1991 Turbo - UK).
Also, boost gauge under reads by .6 bar (also shows -.6 when engine off and ignition on. It should show 1.0) Boost pressure is correct though. Any ideas on either of these?
All other gauges are fine.
Regards,
Andrew
'91 Turbo
Old 10-18-2005, 09:36 PM
Rip It
Rip It's Avatar
u probably have two problems, cure #1 by possibly replacing temp gauge sender. See clarks garage!
Old 10-18-2005, 11:27 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
You could address the engine grounds, a local 944 owner here had the same issues with the tempreature gauge.
Disconnecting the grounds (both battery negative ends, bell housing, driver's side dahsboard, rear boot ground and both headlight grounds) cleared his worries of the tempreature gauge.
Old 10-18-2005, 11:53 PM
420WHP944
420WHP944's Avatar
hi andrew.....good to see you on the rennlist forum!
sorry i'm not able to offer any solutions to your gauge probs but maybe you can with mine????
as you know in my car i have the spa design boost/temp gauge......well, it's working perfect on the boost gauge section but the temp section has stopped reading correctly...ie...it just wanders the entire temp range as if its trying to lock on to the correct temp.....do you think its the gauge at fault or the sensor at the sump????? any thoughts on this would be appreciated......cheers!
Old 10-20-2005, 04:52 AM
promax_motorsport
Default Oil Temp Gauge
Hi John,
I'm a newbie here having stuck with the e-mail list for about 7 years. A lot more activity on the forums now.
Anyway, the gauge is almost certainly fine. It's much more likely to be the sender. You should be able to get them direct from SPA Deisgn for very little ££. I had the sensor stop working once and got a replacement in 2002.
Before replacing sender (in the sump plug) - check the wiring and heat wrap around it as it suffers from the heat of the exhaust downpipe.
I'm in Florida in November (21 - 24), are you around then? All the best.
Regards,
Andrew
Old 10-20-2005, 09:12 PM
420WHP944
420WHP944's Avatar
andrew,
i was thinking the sender was at fault......i'll get another one through spa design....no probs...
yep...im still in fl....we'll meet up for a few beers when you get over....look forward to it.....cheers!
Old 10-21-2005, 01:57 AM
avainio
avainio's Avatar
I just had the exact same temp gauge problem and replacing the sender cured it.
Old 10-21-2005, 02:52 PM
420WHP944
420WHP944's Avatar
yep.....seems thats all the problem is....thanks for the info avainio...
Quick Reply: Temp Gauge & Boost Gauge
