Ignition Diagram needed for running a J&S Safeguard
Old 11-04-2011, 10:38 AM
reno808
reno808's Avatar
doesnt lindsey sells them
Old 11-04-2011, 03:18 PM
alxdgr8
alxdgr8's Avatar
I've got it on Wolf too and have wiring diagrams. Doesn't help for stock DME though.
Old 11-04-2011, 03:25 PM
Paulyy
Professional Hoon
Paulyy's Avatar
I would believe it would be easy to connect since it's only ignition signals and power? but i wouldn't have a clue what to do with the TPS signals.
Old 11-04-2011, 03:44 PM
333pg333
333pg333's Avatar
Originally Posted by Rogue_Ant
None with the stock DME though, AFAIK.
Right...I can't think of anyone with stock DME??
Old 01-19-2016, 08:10 PM
Voith
Voith's Avatar
What is the consensus on these? I am tempted to buy one (interceptor - smart coil specific) for my build but would like some more information on it before I pull the trigger. Its about $1k so not that cheap either.
This is the model:
http://www.jandssafeguard.com/8ChInt...terceptor.html
I would use it with Haltech ps1k.
Have anybody used them and found them to be as good as claims are?
Old 01-20-2016, 02:59 AM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
The J&S units are the best aftermarket knock systems out there...
Interesting fact, John Pizzuto (the designed/owner) reverse-engineered our KLR, and used that as inspiration for his first J&S Safeguard.
Old 01-20-2016, 10:33 AM
gruhsy
gruhsy's Avatar
Edit: never mind found my answer...remembered once I got the to site
I'm at work so a little busy to look more than I have but regarding to J&S which version model are people using on our cars?
Old 01-20-2016, 10:59 AM
Raceboy
Raceboy's Avatar
Unless ECU already has integrated knock detection and action implemented...
Old 12-25-2016, 03:09 AM
John Anthony
5th Gear
John Anthony's Avatar
Sorry for the confusion but no, I did not reverse engineer the KLR.
At the time, I was a technician at Hughes Aircraft. In my spare time, I was working on an analog "retard all" knock controller when the Road & Track article on the 944 Turbo came out.
I hadn't thought of individual cylinder control until I saw the article. The fact that it could be done through a distributor is all I needed to get started. I became obsessed with making one for my Fiat 131 with home brew turbo.
I knew it would have to be a digital controller, but I had no experience. I bought a surplus AIM 65 uP trainer and started learning 6502 assembly code. This was a fortunate choice, since it was very similar to the 68HC11 used in the early SafeGuards.
My analog system had a pretty good scheme to filter out piston slap. I came up with a software algorithm to do it digitally, and tested it on the AIM.
That formed the basis of the SafeGuard's thresholding and detection scheme.
By then it was 1989, when Hughes "gave me the opportunity" to work full time on the project.
While Steve Dinan was buying the analog controller from me for his turbo kits and repackaging it (a box within a nicer box), I continued working on the digital version, taking two more years to make it work as well as the analog version, releasing it in 1991.
Old 12-25-2016, 05:09 AM
Raceboy
Raceboy's Avatar
Thanks for sharing John! It's always nice to hear about how things started! Happy holidays!
Old 12-25-2016, 06:26 AM
John Anthony
5th Gear
Thank you, and Merry Christmas to all.
Old 12-25-2016, 12:59 PM
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
I have one, very nice work John and a great story! Thanks for sharing, Merry Christmas!
Old 12-26-2016, 05:56 PM
Pauerman
Pauerman's Avatar
Love your knock controller John - been using them with great success for years.
Quick Reply: Ignition Diagram needed for running a J&S Safeguard
