Ignition Diagram needed for running a J&S Safeguard
Old 05-24-2006, 02:50 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Default Ignition Diagram needed for running a J&S Safeguard. Edit, need someone with a scope
I need an ignition diagram that shows the ignition module and coil. I currently have a J&S Safeguard that I would like to use, but John (owner of J&S) needs these diagrams to help me get started.
Anyone use a J&S instead of the KLR, or knows how to hook it up correctly?
Rogue
Old 05-24-2006, 05:26 PM
Rogue_Ant
Rogue_Ant's Avatar
This is taken from an email from John @ J&S (http://www.jandssafeguard.com/)
By the way, Road and Track magazine did a review of the 944 turbo in '87.
Their praise of the Bosch knock detector inspired me to design the J&S unit.
By comparison, the Bosch unit was crude, considering it retarded three
degrees, then three more if knock persisted.
Does anyone have any diagrams so I can figure out exactly how to wire my J&S in?
Rogue
Old 05-25-2006, 02:49 AM
Rogue_Ant
Rogue_Ant's Avatar
Nobody has a diagram? Or can point me the right direction?
Rogue
Old 05-25-2006, 03:19 AM
theedge
theedge's Avatar
These might help?
http://thedge.info/rennlist/5.jpg
http://thedge.info/rennlist/6.jpg
Old 05-25-2006, 03:34 AM
cpt_koolbeenz
cpt_koolbeenz's Avatar
You mean something like this?
http://users.adelphia.net/~robertlange/Rennlist/1.jpg
Old 05-25-2006, 09:24 PM
Rogue_Ant
Rogue_Ant's Avatar
Thanks for the diagrams!!
Does the fuel pump relay connects to the coil negativer?
Rogue
Old 06-17-2006, 02:58 AM
Rogue_Ant
Rogue_Ant's Avatar
Ok, I'm getting somewhere...
Anyone know if the 'spark event' signal from the DME (pin 21) to the KLR (pin 9) is a 'rising edge input trigger', and likewise if the signal sent back to the DME from the KLR (KLR pin 16 to DME pin 32) is a 'rising edge output trigger'?
Also does anyone know the Voltage of this signal?
Rogue
Old 06-17-2006, 04:29 PM
Rogue_Ant
Rogue_Ant's Avatar
Anyone???
Rogue
Old 06-17-2006, 09:02 PM
AlexE
AlexE's Avatar
marksportcts used to run a J&S when he had his callaway 944.
I have not heard from Mark in a while. He hangs around here and pelican. I am sure he would be able to answer your question. It may be worth a shot PM him.
Old 06-18-2006, 01:41 AM
Rogue_Ant
Rogue_Ant's Avatar
Thanks, will give it a shot.
Rogue
Old 11-04-2011, 01:12 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Did you end up installing this?
Old 11-04-2011, 01:36 AM
Rogue_Ant
Rogue_Ant's Avatar
5 year old thread.. Your digging skills are impressive!
You have a PM.
Old 11-04-2011, 03:36 AM
333pg333
333pg333's Avatar
There are a few guys out there running these. Check on Pelican site for NIZE and others. Vic from Pauertuning also runs one. http://www.pauertuning.com/
Old 11-04-2011, 03:46 AM
Rogue_Ant
Rogue_Ant's Avatar
None with the stock DME though, AFAIK.
Old 11-04-2011, 04:44 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Nize is running a Wolf 3D or a V500 with a J&S and Vic is running his with his ViPec ems.
Quick Reply: Ignition Diagram needed for running a J&S Safeguard
