Street/Track Allignment Specs
Old 05-31-2006, 06:22 PM
CO951
CO951's Avatar
Default Street/Track Allignment Specs
I did a search for allignment specs and didn't find much. I found these, but I'm not sure if the are for street or track.
Rear:
Toe: 0 +/- 0.08 degrees. Max. difference 0.17 degrees
Camber: -1 +/- 0.33 degrees. Max. difference 0.5 degrees
Front:
Toe: -0.17 +/- 0.08 degrees
Camber: -0.33 +/- 0.25 degrees. Max. difference 0.17 degrees
Caster: 2.5 + 0.5 - 0.25 degrees. Max. difference 0.5 degrees
I'm guessing these are street specs.
I'm looking for specs for street/track use for my '89 951.
Old 06-01-2006, 12:50 PM
ninefiveone
ninefiveone's Avatar
That's a street spec.
For track/street (more track than street) I run more camber. About 1.5 all around.
Old 06-01-2006, 08:42 PM
CO951
CO951's Avatar
So just run more negative camber. That's easy enough. Thanks!
Old 06-02-2006, 05:26 AM
Sami951
Sami951's Avatar
I've been running with zero toe in front for few years now and it seems to work really well, still goes straight without problems but turns in just a bit faster.
In the rear a bit of toe in might be nice, depends on how you drive and if you have LSD or not - as it helps keep the rear end settled during hard braking. At the moment I've got -0.10 toe + LSD and it's very stable.
Old 06-02-2006, 07:00 AM
JET951
JET951's Avatar
if you run standard bushings on the front control arms then i would run 1 mm toe in because on braking it tends to open up because of the play in the bushes.
Old 06-03-2006, 11:48 AM
jimbo1111
jimbo1111's Avatar
For a street track setup I went with 1.8 deg negative camber up front and 2.0 in the rear. Set the caster as far as it will go. Close to 3 degs. With a 1 mm toe in.
Old 06-03-2006, 07:02 PM
azmi951
azmi951's Avatar
Only on early offset cars since it has an inside scrub radius. on late offset cars the outside scrub radius makes toe in under braking. this is also primarily due to pneumatic trail of the tires.
Quick Reply: Street/Track Allignment Specs
