Giving up on my project :(
Due to circumstances beyond my control, it is now officially time for me to give up on my project 951
For those of you that don't know, I was in the process of building a 3.4L 951 with all the goodies... but not anymore...
So, does anyone want any of the project parts? I have all the parts to complete the project. For that matter I have a complete 951 as well.
I'd be willing to sell parts and/or trade stuff for a complete stock 951 or something along those lines.
I have about 100 MB of photos of the stuff I have for the project car at http://www.paradoxengineering.com/chris/944photos.zip
If anyone wants to take the project and actually finish it, that would be sweet; someone should get this done, but unfortunately it can't be me. Otherwise, parts are up for grabs... make offers if you need anything and I'll pull it for you.
1987 Porsche 944 Turbo
Body
Fiberglass hood
Fiberglass +2 front fenders, modified to use European side repeaters
Fiberglass front bumper (2 of them, 1 is installed, 1 is brand new)
Vented nose panel (OEM metal)
New, never installed hood crest included with gasket
968 turbo RS adjustable replica fiberglass wing + trim (not installed)
968 mirrors (OEM, new in box, includes all hardware, gaskets, etc.)
968 door handles (OEM, new in box, includes all hardware, gaskets, etc.)
OEM Porsche Carrera 2 wheels (18) with brand new Yokohama tires 295 in the rear!
Silver powder coated lug nuts and wheel locks (not pictured)
Turbo-script wheel centers
Lighting
Hella headlight housings
100W Xenon bulbs
Euro driving + fog lights
Rear brake lights modified to light up the bottom rectangles, instead of the large rectangles towards the middle
Suspension
HR stage 1 suspension (full coil-overs)
600# front springs, 800# rear springs
Adjustable camber/castor plates up front
Torsion bars removed
Adjustable ride height dropped to ~3.5
Brakes
Stock calipers
Zimmerman cryo-frozen cross drilled rotors
Mintex C-Tech pads
928 GT brake bias valve
Stencils to apply factory PORSCHE logo to new calipers (or painted calipers)
Interior
Stock leather seats
GT2 carbon fiber / aluminum 6-speed shifter with Porsche crest ($250!!)
HR gauge pod with VDO boost, oil temp, and EGT gauges
One-touch window up/down (both passenger and driver side)
Clifford Polaris G3 alarm with ignition kill; blinky light integrated in to door lock light and programming switch uses a factory switch
2x Phoenix Gold XS-series amps (~1000W)
JL Audio 12W6 12 sub mounted in spare tire well (sealed)
Infinity Kappa 6.5 separates front and rear (8 main speakers)
Infinity Kappa 6x9 speakers in custom boxes in rear cubby holes (dual tweeters)
Dynamat extreme applied to doors and entire rear section of interior
0.5F capacitor
Airbags (stock)
Power locks, etc.
GPS receiver mounted to third brake light
Engine (old)
Includes lower half of stock engine (oil pan, pullies, header, exhaust, turbo, intercooler, AC, alternator, etc. - everything mechanical)
AC would blow cold (recharged just before engine died)
Engine (new)
3.379L Engine:
o 968 block, bored to 108mm, ChMo sleeves, block cement underfilled, balance shafts welded shut and JB weld over the welds to ensure they dont leak
o 968 crank, offset ground to 92mm, lightened, knifedged, cross drilled, etc
o Pauter rods, gun drilled, special rod bearings included
o JE pistons, thermal coated tops, includes rings, pins, etc.
o 16V head (needs rebuild probably)
o 4-1 custom headers with decreasing radius (spec stolen from some famous guy I cant remember), thermal coated, V-band clamp
o V-band clamp crossover pipe, thermal coated
o Down pipe for 60-1 turbo, thermal coated
o Turbo is a 60-1 something or other turbo will be v-band clamped
o Cometic 3-ply all metal head gasket
o Super mount engine mounts
EFI
o Wolf3D v4 ECU, wiring harness, etc. with wideband O2 sensor upgrade, mounted in factory ECU location. Includes all manuals, connectors, etc. that came with the ECU
Misc.
Misc. crap including spark plug wires, K&N air filters, 16V stock cams, map pockets, trim pieces, weather stripping, etc.
Body
Fiberglass hood
Lighting
100W Xenon bulbs
Suspension
Brakes
Stock calipers
Mintex C-Tech pads
Interior
Stock leather seats
0.5F capacitor
Airbags (stock)
Power locks, etc.
Engine (old)
Engine (new)
3.379L Engine:
EFI
Misc.
Sam
Damit, that page isn't loading for me, I would love to see pictures of this car. You have obviously put many many hours into this auto. Hopefully you do sell it to a buyer who understands and appreciates all the hard work.....I mean , who wouldn't want a 3.3 ltr turbo?
Basic Sponsor
I sent a pm yesterday and still no response. I am interested in the whole project because I want to fisnish it no part it out.
