944 goes BOOM, lots of smoke out tail.
Old 07-19-2006, 04:55 PM
MPD47
The Carnage King
MPD47's Avatar
Default 944 goes BOOM, lots of smoke out tail.
So as I posted before, I popped the radiator in Indiana. I suspected it was due to plastic end tanks and ****ty Indiana roads (seriously worst roads ever). When I got it home though, I noticed I was blowing some vapor out the tail pipe, and hitting on 3 when I wasnt under load, and hitting on 4 when I gave it some gas. Hmmm sounds like a headgasket to me....
I suspect it was due to the lean pops from the issue with the crank trigger reading interferance off the alternator, causing the engine management to freak out. We'll see if I've corrected that when it's back together. Oh yeah, and as a note.... remember to jack your camber plates out before driving a few thousand miles... was still running my track alignment for Rochester - Buffalo - Chicago - Indianapolis... whoops!
Thankfully I have more 255/35R18 S03's ready to go on the front
Old 07-19-2006, 05:02 PM
lart951
Basic Sponsor
lart951's Avatar
How much boost are you running Mike?
Old 07-19-2006, 05:05 PM
MPD47
The Carnage King
MPD47's Avatar
Depends on the day. Daily, 17psi. I've turned it up for a run or two before with 100 octane in the system on the dyno. I'm pretty sure this was caused by the hiccup though.
Old 07-19-2006, 05:33 PM
TRP951
TRP951's Avatar
that sucks mike but you have done many repairs and upgrades on your 951 so the down time should be minimal. Also my car is close to completion probably this weekend
Old 07-19-2006, 05:43 PM
cpt_koolbeenz
cpt_koolbeenz's Avatar
What gasket are you going with? I had my reserves about the MLS, but 3000 miles and no problems (knock on wood).
Old 07-19-2006, 05:48 PM
Ski
Ski's Avatar
and on #1??!!! When I saw this I was guessing #4 again for someone...hmmm
Chris, so you went with the Cometic...just took your time on the install and double checked the layers? Glad it all worked out.
Old 07-19-2006, 05:56 PM
cpt_koolbeenz
Sure did... It was not hard... I was just worried about all the guys that did that and still had leaks. But no issues here, but I'm sure I will post if I do! LOL
Old 07-19-2006, 06:01 PM
testarossa_td
testarossa_td's Avatar
Thanks for the post...your lessons are teaching us all...and saving us tons
Old 07-19-2006, 10:27 PM
MPD47
The Carnage King
MPD47's Avatar
You're welcome. God I hate doing headgaskets on these cars. I can drop an engine quicker!
Old 07-20-2006, 12:29 AM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Mike, how many head gaskets have you gone through till now?
Old 07-20-2006, 12:45 AM
DDP
Rocket Scientist
DDP's Avatar
Ditto on clutches.
Old 07-20-2006, 02:00 AM
Eyal 951
Eyal 951's Avatar
I'd rather do the HG again then the turbo again. Oh look:
Old 07-20-2006, 02:03 AM
Eyal 951
Eyal 951's Avatar
I've been sidetracked by this however:
Old 07-20-2006, 11:40 AM
MPD47
The Carnage King
MPD47's Avatar
1st one on this car, the other one has had one also (bought it blown up) and I've done one on a friend's car.
Old 07-20-2006, 03:08 PM
DDP
Rocket Scientist
DDP's Avatar
At least your cylinder walls look great.
Quick Reply: 944 goes BOOM, lots of smoke out tail.
