Purpose for timing belt cover breather hose?
The one that goes from the top of the belt cove to the airbox cover. Mine was missing and not capped when I got the car, so I ordered a new breather hose. Now I'm wondering why you would want to suck air out of there, it seems like it would just be more likely to suck dirt in it. Would it be for cooling? Any ideas?
Hmm, 88 is pretty close to '89. Does anyone with an '89 have the tube?
Any explanation on why it was there in the first place, and why just capped on later cars?
Its purpose was to provide a "slight" vacuum in the belt cover area to suck up any belt particles and other junk that may accumulate in the belt covers. It's designed to deposit it on top of the air filter that way it can be cleaned upon filter change. It wasn't a very effective system so it was just capped off. I believe the change happened in mid 88.
Thanks Jeremy.
IanS- just curious, why are you capping yours?
I'm trying to decide if I should just use the hose now that I have it or cap them off.
is this hose the same as one from an N/A? i have an N/A hose from an 89. I pulled mine and left it open. Many came w/o them and are open but if you look down in the hole, they are molded closed inside of the tube.
Originally Posted by kevincnc
Thanks Jeremy.
