Rear Speaker Size?
If you do go with 6.5's in the rear, you can get the factory grills that were used in the 10 speaker option cars. I think they finish it off pretty nice...
http://forums.rennlist.com/upload/9...small_copy1.jpg
IIRC they go for about $30 apiece new but used ones can be had fo much less...
if i did it again?
i'd take the cubby hole covers, put a piece of luan between the carpet and the foam, and install 6 x 9 speakers.
the 6.5's are better than the 4 x 6 Oem's but the factory quarter panels muffle the sound. my front spakers are 4" mid range drivers with 1 " tweeter and quite frankly sound better beccause they are unobstructed.
for me.........i'd use the ones i have in the front, disconnect the factory, leave the stupid quarter panels in place since they are a pain to work with, and put bigger, better, clearer speakers in the rear.
fwiw
fwiw
Does anyone have any pics of the rear 10-speaker-system speaker covers? I've been searching through the forum for probably 30min now but haven't been able to find any pics of them yet (only a lot of broken links).
greg. is it the rear panels or just grills that fit to the stock 4-speaker system rear panels? If you are selling the panels, I will buy them. Can you shoot me some pics?
Danny,
Just the speaker grills. I was going to convert my 4 speaker system to use these grills in back but they were backordered at Sunset and I ended up just mounting my tweeter in the panel w/o the grills.
For pics, try this one... For some reason the link I posted above doesn't work from here, but it still seems to work in the original post...
https://rennlist.com/forums/924-931-944-951-968-forum/203736-rear-6-5-round-speaker-walkthrough-what-exactly-is-required.html
Hey Man
Originally Posted by potent951turbo86
Cutting the body just to fit some larger speakers leaves a bad taste in my mouth. I would choose many others ways first if it were me.
Originally Posted by IanS
How are the larger grills going to look over the regular 4 speaker panels? I assume the picture in the other thread was of the full 10 speaker panels?
Hey Guys
Not to pee on anyone's feet but as nice as those grills look there is one major set- back to keep in mind ...
When Porsche ( not really know for great sound systems ) put those grills in the car they were to function as actually holding directly behind the grills these ****ty( and I use the term very conservatively ) little speakers that rival only those in a old transistor radio ...
I was extremely disappointed, after I busted my ***, fitting in ADS S7's, that the actual hole, where one would mount the speaker in the body of the car, was very different than the location of that grill ( it misses by 4 inches ??? I really can't remember, as I did it over 15 yrs ago )
I even had to used an old rubber soap eraser, to space out the interior body panel that the grill attaches to, because the throw of the speaker would interfere with the speakers movement. I just wanted to let anyone know who may think that this is the end all, that it's really a poor design. In fact ironically it was kind of a step back, unlike all the other moves they made to the TS car (at the time I didn't feel it was as critical, because I was using it as a sub and Bass is supposed to be omin-directional?).
In fairness, I will say that the front set up was a step in the right direction, although the plastic mounting shell in the front doors has a lot to be desired ( to remedy this....Don't Laugh!
I filled mine with bondo. It made an incredible difference in the resonance.....
Good luck to all
Regards
Ed
Good luck to all
Regards
Ed
Originally Posted by KuHL 951
Funny that cutting a mere 1.5" crescent of thin sheet metal where it can't be seen would bother you but adding a Euro bumper and your extensive list of mods is OK? Where's the bad taste? I cut mine just last weekend for 6.5's. It took all of 5 minutes total and doesn't show with the adaptor plate padded and installed.
but you probably knew that Steve
regards
Ed
So I have a 86 and Im going tomorrow to buy speakers, I'd like to do the stock 4 by 6 in the front and go 6 and a half in the rear, What needs to be done? I don't mind trimming metal, I just would like them to fit behind the stock grills
