Interest in a “plug and play” EGT probe kit?
Old 10-31-2006, 02:28 AM
Laust Pedersen
Laust Pedersen's Avatar
Default Interest in a “plug and play” EGT probe kit?
Those who have read the “EGT probe NON weld?” thread may have noticed that I helped Rick (RK951) with a custom installation of an EGT probe in the cross-over pipe as a substitute for the test tube.
After a number of trial and errors it actually came out well and we assume that it may have general interest for those who want to monitor their EGT, but don’t want to go through the hassle of welding/installing a bung in their header.
So therefore I would like to hear who would be interested in a “plug and play” EGT probe kit, consisting of a custom EGT probe with appropriate cable length, custom ferrule, custom stainless nut, installation instruction and a few minor items such as spade connectors and cable ties. All for $98 + S&H (which may be about $8 domestically and twice that internationally).
Rick posted some pictures here .
The probe is based on a K-type thermocouple, which is compatible with 99% of the EGT gauges on the market. As most other probes it has closed tip (more rugged).
Based on my very short test drive the response is quite similar to my probe(s) mounted near the cylinder head ports, except during warm-up and under idle on a cool day, where it as expected is a little cooler.
The installation is fully reversible, meaning that the test tube can be installed again if you for some reason want to return to stock configuration.
Again, please let me know here if you are interested and I will start making some kits.
Early list of interested Rennlisters:
Ross255 (1)
Turbo Fanatic (2)
Laust
Old 10-31-2006, 02:51 AM
TRP951
TRP951's Avatar
How accurate is this compared to the ones in your headers? Do you have any datalogs?
Old 10-31-2006, 03:15 AM
Trucho-951
Trucho-951's Avatar
I'm interested.
Old 10-31-2006, 07:40 AM
marcoturbo
marcoturbo's Avatar
I'm also interested.
Old 10-31-2006, 08:05 AM
tconn
tconn's Avatar
I'm interested. But would like to see how accurate it is compared to one mounted in the header.
Old 10-31-2006, 10:03 AM
Keith E.
Keith E.'s Avatar
I'm in.
Old 10-31-2006, 10:22 AM
Duke
Duke's Avatar
The only thing up for debate is if the ring type spanner was the best tool of choice for installation
Old 10-31-2006, 10:48 AM
eclou
eclou's Avatar
Received 1,156 Likes on 571 Posts
I'm in
Old 10-31-2006, 10:51 AM
SamGrant951
SamGrant951's Avatar
Interested. edit: I'll take one.
Old 10-31-2006, 11:21 AM
Frank@Work
Frank@Work's Avatar
If it can be hooked up to a Zeitronix I am interested!
Old 10-31-2006, 11:41 AM
Buckaroo Banzi
Buckaroo Banzi's Avatar
Default Sign me up...
Add me to the list...
-BB
Old 10-31-2006, 11:48 AM
35thSLP
35thSLP's Avatar
I'm interested as well.
Old 10-31-2006, 02:18 PM
Laust Pedersen
It measures the gas temperature where it is located as accurately as any EGT probe. Maybe the question is if the temperatures measured are identical to a (top of the) header location. Bases on my observations after one test drive (comparing Rick’s and my cars) they are very similar once the engine is hot and with adequate exhaust flow (slightly lower temperatures at idle).
I don’t have and will probably not in a foreseeable future get any logged data, but maybe in a week or two I’ll move one of my 4 probes down to the X-over location and will let you all know in more detail how they compare.
Btw, as with most instruments installed to monitor a parameter on a well-functioning engine you first get a sense of how the parameter behaves under different conditions, after that it becomes much easier to detect any creeping or abrupt abnormality.
Originally Posted by Duke
The only thing up for debate is if the ring type spanner was the best tool of choice for installation.
I just did that to show that it was possible to thread a closed wrench onto the nut … and remove it again BEFORE the wire has been routed, otherwise just leave it there for next removal . An open wrench works too.
Originally Posted by SamGrant951
Interested - (will it work with the Zeitronix?)
If the Zeitronix has an EGT input then it will work, but I will look into the details a little further.
Laust
Old 10-31-2006, 02:49 PM
PCinDC
Rennlist Lifetime Member
PCinDC's Avatar
The Zeitronix uses a K type thermocouple so I think you guys are fine using this with the ZT2.
Old 10-31-2006, 03:32 PM
Jeremy Himsel
Jeremy Himsel's Avatar
I'll take one as well.
Quick Reply: Interest in a “plug and play” EGT probe kit?
