Crap! Just got a boost leak.
Old 10-27-2006, 03:57 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
Thumbs down Crap! Just got a boost leak.
I am getting, and jsut happened today, only about 8-10 psi. I assume a crack or split somewhere as boost is being made and then the leak gives way and only makes/holds 8-10 psi.
Also, it is really loud in regards to hearing the turbo spooling or the amount of air leaking. but if still making/holding about 10psi, it can't be that big/obvious a leak...????
Well, idle is fine so I am sure it is after the turbo and not a vac leak.
All hoses/boost lines are pretty much new.
Bigger turbo and Tial so that eliminates those issues.
Billet DV, but I guess I can check it also.
I will do a pressure test when I get home from work and hopefully will find it easy.
Old 10-27-2006, 04:08 PM
Thom
Thom's Avatar
Failed exhaust gasket between CO pipe and WG ?
Old 10-27-2006, 04:11 PM
toddk911
toddk911's Avatar
Possibly. I am thinking someting in the exhaust/headers etc.
Old 10-27-2006, 04:19 PM
Ski
Ski's Avatar
which billet valve?
Old 10-27-2006, 06:12 PM
rberry951
Temprarily Banned per IB
rberry951's Avatar
Do you have stock CO pipe? If so look at the CO2 bung and see if it rotted and cracked open.
Old 10-27-2006, 11:49 PM
TRACKIN951
TRACKIN951's Avatar
I would say check your j boot, but that probably wouldnt allow 9psi of boost. You would probably feel the boost cut if it was. if that helps
Old 10-30-2006, 10:53 AM
toddk911
toddk911's Avatar
Pressurized the top side and everything looks fine.
Pulled the DV and all is well.
I am thinking it is exhaust side. Also it is very loud as I can here the leak or turbo really spooling.
Old 10-30-2006, 02:00 PM
EJ
EJ's Avatar
Smile
How long has the tial been installed? If you did not lock the bolts on the adapters in some way they could have come loose. Happened to me.
Old 10-30-2006, 02:02 PM
toddk911
toddk911's Avatar
Tial has been on about a year or so.
I will get the car up and check all the exhaust soon.
Old 10-30-2006, 02:03 PM
toddk911
toddk911's Avatar
It seems to spool pretty normal, but then at 8-10, jsut stops and then really hear the turbo/leak from outside.
Old 11-01-2006, 10:32 AM
toddk911
toddk911's Avatar
Ski: Sorry. The DV is an Evolution Motorsports, billet.
Old 11-01-2006, 11:07 AM
Maciek
Maciek's Avatar
Todd, check the rubber hose that connects the turbo to the intercooler pipe. I also pressurized my entire intake side (except for this hose) and couldn't find it. Your symptoms sound identical to mine and I had a huge tear in that hose. It is a difficult hose to see so use your hands to feel it and see if there is a tear. It may be worth pulling out as its only like a 15 minute job.
Good luck.
Old 11-01-2006, 11:27 AM
toddk911
toddk911's Avatar
That is a newer hose but I will check it out. Thanks!
Old 11-01-2006, 06:21 PM
amschnellsten
amschnellsten's Avatar
do you know anyone with a smoke tester. i had a bosst leak foreever and could not find it. Bought a smoke tester and it works really well. It will only go to 20 psi but if you are runnig less they are worth the money.
Old 11-01-2006, 09:17 PM
toddk911
toddk911's Avatar
SHOULD THE FRONT SIDE/COLD SIDE OF MY TURBO BE LOOSE?????
I am thinking NOT. But before I blast the company that sold me this turbo (as a replacement for their ruebuilt turbo that blew to ****)
Anyone???
As I was checking the turbo to IC hose, I tugged and noticed the turbo was moving back and forth on the front/clode side.
Fixable??
If so, is this a turbo I should keep???
Quick Reply: Crap! Just got a boost leak.
