WHAT is MORE IMPORTANT OIL PRESSURE OR OIL TEMP?
Originally Posted by reno808
How do you like? How was installation?
i plan to put it right under where the radio use to be. along with the boost and the narrow band gauge
I got the plate from lindsey however you can make your own. I can give you the diementions if you need it.
Originally Posted by 9fitty1
If the oil level is too high the crank can contact the oil creating foam. Foam in the oil = spun bearing.
the two are directly related. As oil heats up, it gets thinner, and because it flows easier it builds up less pressure in the oil system. As long as you have above 1 bar at idle when you come in you are fine.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Don’t fill past the full mark!
Temp and pressure are closely related – the stock pressure gauge works pretty well so if you only want to add one add temp (and then be prepared to add the oil cooler when you find out how hot it really is!)
Mission critical gauges should not go under the radio – you will not see it until way after it matters when you are out on the track. The big plus of the stock pressure monitoring system is that there is a separate warning light system that will get your attention.
mmmm for now i'll add the oil temp gauge. If i see my oil is getting to hot or my presssure is dropping then i will add the dual digital guage. BTW how much is it?
Originally Posted by ibkevin
Let's see...
You can make it as hot as you want, but without pressure, you're done!
Crank scraper, windage tray?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Defending the Border
Rest In Peace
Rest In Peace
Sorry Matt!
And I realize that temp plays a large part in visciosity...
but with enough pressure, low visciosity will still lubricate...
