How Much HP Should There Be?
Old 01-24-2007, 10:53 AM
Dr. Dynamics
Dr. Dynamics's Avatar
Angry How Much HP Should There Be?
Just want to know your guys opinion on how much hp a 2.5L 951 with the following mods should be doing
- Vitesse Stage III turbo Kit w. fuel management/MAF etc...
- Lindsey 4" full exhaust
- lindsey Wastegate
- Custom Head Port w/ racing springs and 5 angle valve job
- Matched Ported Stock Intake
- Lindsey fuel rail & Pump
- SFR Stage I header
- SPEC Clutch
- Raceware studs (low and high)
- AFR = 12
- 21 psi boost
Old 01-24-2007, 11:00 AM
toddk911
Drive-by provocation guy
toddk911's Avatar
350whp
Old 01-24-2007, 11:04 AM
pete95zhn
Former Vendor
pete95zhn's Avatar
Let me make a wild guess based on your write-up:
Not as much as you thought it would do...?? Like 330 rwhp?
wi54545
wi54545's Avatar
At 21psi? 400
Old 01-24-2007, 11:07 AM
Landjet
Landjet's Avatar
I have some other internal and external mods you don't have but it's pretty close to the same stuff. I hit 360 HP at the rear wheels running 18 psi of boost and still have a miss that I can't figure out, so there is still room for improvement. You should easily get my numbers at 21.
Old 01-24-2007, 11:34 AM
cantresjr
cantresjr's Avatar
Sounds like Juancho's car
Old 01-24-2007, 12:10 PM
SoloRacer
SoloRacer's Avatar
My car made in the range of 300 rwhp at 15 psi with a Vitesse Stage III, SFR Exhaust, Stock Head. I believe John says to expect 13 rwhp per each psi of boost over that which should put you in the 350-375 rwhp range. Just a guess.
Old 01-24-2007, 12:28 PM
MPD47
The Carnage King
MPD47's Avatar
400whp +/-
From someone who owned that turbo.
Here is a chart from me, except I had a crank trigger miss that day which caused us to call it quits on the dyno (my own stupid fault).
That was 20psi(?) if I recall correctly. Less intake/head mods than you, but MAP/Tec3R instead of MAF.
Old 01-24-2007, 12:41 PM
RolexNJ
RolexNJ's Avatar
Originally Posted by MPD47
400whp +/- From someone who owned that turbo. That was 20psi(?) or 19, I cant remember.
So Mike, were your mods the same as is - apples to apples? Or no. And man, you guys kill me with scanning these dyno charts, I can't see crap. It's dark, no RPM to see, and no A/F plots too. Then again pal I can't blame, for this is pretty much the norm around here somtimes, no offense pal.
Old 01-24-2007, 12:44 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
If i recall, ST pushed out just a tad over 400whp at 25psi (race timing + xyline) on a bone stock engine. With you're uprades (exhaust + head) you should be pushing in that ball park with the same ignition/fuel and 21psi boost or so.
*just thinking out loud*
MPD47
The Carnage King
MPD47's Avatar
I never scanned it as it was a crap chart. When I have a CLEAN chart, I'll scan one with all the info.
As for mods, it was
Lindsey Rail Kit - 72# Hour injectors
Vitesse Stage III
Tec3R - MAP Sensor - Coil packs
Lindsey 3"
Spec clutch
Lindsey Stage V
Everything else was stock IIRC. So he has a bigger exhaust, worked head/intake over what I had. But I was running different management/spark.
Old 01-24-2007, 12:45 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
Isn't the AFR of 12.0 a bit rich?
Old 01-24-2007, 12:47 PM
Porsche-O-Phile
With a k26/6? That sounds wildly optimistic, IMO.
You might get 25 psi with a k26/6 (IIRC Laust Pedersen did this to test out some water injection stuff a while ago) but at that point the turbo is so totally inefficient and is making so much heat it's probably a detriment rather than a benefit.
Old 01-24-2007, 12:48 PM
MPD47
The Carnage King
MPD47's Avatar
Jeff, no, stock engine other than Turbo/managment/MAF/injectors is what he means.
Old 01-24-2007, 12:50 PM
hosrom_951
hosrom_951's Avatar
Jeff, as Mike pointed out, i missed out on something....
A VR Stage 3 Kit on a bone stock engine (stock internal block/head/valves, exhaust system + headers).
For obvious reasons, the injectors were not stock (72lbs at that time i believe).
Quick Reply: How Much HP Should There Be?
