classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#61 |
Rennlist Member Join Date: Dec 2007
Ok, I'm going to try this and see how it goes. First I'm going to get some measurements on the "early" 944 ALT jsut to be sure, but if still too big I'll go with the ENIAC setup. I'll report back when underway. Everything except the ALT is off already and out to various shops for service.
'90 944S2 Cabriolet -- 94,000 miles, restored. last one... '86 944 Turbo resto-mod-- Recently Sold... snif, sob... ’90 944S2 – Sold. ’87 944 – Dead.[/size][/font] |
#62 |
Rennlist Member Join Date: Aug 2005
I was thinking about doing this. What is the stock alternators amperage output? I was thinking it was less than this one's. If it is less, has anyone thought of using the pully that comes with this alternator so it will turn slower and have less of a load on the engine? Or would the difference in load be to little to be of significance?
Michael Stieger <- Why is my name here? FOR SALE: 1989 Guards Red 951 w/ LBE, Euro Fog/Driving Lights, Experimental Chips, Shimmed WG, 5/33 Brake Bias Valve, SS Brake Lines, 968 Brake Cooling Scoops, 968 MO30 Sways, Laust vacuum manifold, KISS oil cooler, Disemboweled feline (gutted cat) 2001 Zanzibar Red Boxster - SOLD
#63 |
Rennlist Member Join Date: Jul 2009
usually 3 wires
the big terminal should be red and goes to the starter/battery the 2 pins: one is a ground (brown or bare) one is for the idiot light in the cluster (black) usually you need a wiring diagram for the nissan meter (ohms) each pin to the case...that will tell you which is ground...the other should be for the idiot light |
#64 | |||
If you want to use the Nissan quest alternator used in this thread, then all the install instructions are here, including how to wire it to the 944.
Mark...Giggidy giggidy. Giggidy goo. Quote:
Quote:
Quote:
MaxHP chip - Port matched/polished head - Throttle Cam (Don't we all) - Drilled Sebro rotors and PBR Metal Master pads -Blaupunkt Brisbane SD stereo - Rennbay Headlight Kit |
#65 | |
Rennlist Member |
Quote:
~Stephen Autocore autocore@gmail.com AIM: Eniac325ix '88 951 White - MAP, AVC-R, big turbo, 86lb/hr injectors, small 130 amp Nissan alternator, Cobra Misano's, cold r134 A/C, 30psi with 35 psi scatter boost, E85(Looking for a decently priced 4" exhaust). NO BELT COVERS! '72 914 - 100% stock w/ Jetronic D fuel injection. 2009 Human Girl - Ophelia - Born Aug 14 at 11:57am. 7lb 7oz. OMG! Ima daddy!!! Last edited by eniac; 09-12-2009 at 08:54 AM. |
#66 |
Rennlist Member |
btw, here's a long term update. ~25,000 miles and over 2 years later it is still working fine and I haven't had to touch it. Recently, I do get some belt squeek for a few seconds after a hard start with the blower, radio, and lights on so I think it's time to retension the belt. That's it.
No issues at all with this setup.
~Stephen Autocore autocore@gmail.com AIM: Eniac325ix '88 951 White - MAP, AVC-R, big turbo, 86lb/hr injectors, small 130 amp Nissan alternator, Cobra Misano's, cold r134 A/C, 30psi with 35 psi scatter boost, E85(Looking for a decently priced 4" exhaust). NO BELT COVERS! '72 914 - 100% stock w/ Jetronic D fuel injection. 2009 Human Girl - Ophelia - Born Aug 14 at 11:57am. 7lb 7oz. OMG! Ima daddy!!! |
#67 | |
Rennlist Member |
Quote:
#68 |
I wasn't asking about the wirring! I was asking about how many amps the alternators can produce. I was thinking the stock was 110amps. How much more is the Nissan one rated?
Did you have any pics of the mods you made to the alternator housing? I know the hole was drilled out, but I didn't quite understand where the area that was ground down is.
#69 | |
Rennlist Member Join Date: Feb 2002
Quote:
Most alternator run a 2-3 to one ratio so 6K rpm at the alternator is 2-3K rpms on the Engine. Last edited by Brian Broderick; 09-14-2009 at 08:37 PM. |
#70 |
Rennlist Member Join Date: May 2005
Read his signature as well, just above the photo he posted.
BTW, I had a zanzibar red boxster S, it was a cool color. |
#71 |
Here is a photo of the Nissan alternator installed on my engine out of the car. I do have a larger pulley I am going to use to hopefully retain the stock belt.
#72 | ||
Rennlist Member |
Quote:
![]() Quote:
![]() Thanks for posting a pic. Difficult to do with mine since it's in the car. I had to get a different length belt but with the pulley from the Porsche alt I was able to keep the same 6 rib width belt.
#73 | |||
OK, so I'm attempting to do this. I don't know if there are different casings for the nissan alternator or what, but I am having to cut away a TON of the mount. I've almost got it now but GOD DAMN! I've cut the slot for the alternator bolt, and I've sanded away 1/2 the mount on 90% of the alternator area.
The pully shaft doesn't have a woodruff key. Its on there tight (impact), but I hope it doesn't slip. The write up on installing this is right on, there is just more to do than you'd think. Maybe the NA mounts are a little different than the turbo mounts? Maybe my alternator is a bit different? Who knows. Ok, back to my sanding/grinding/cussing/bleeding..... I'll chime back in when its done.
Quote:
#74 | |||
FOR THE LOVE OF ALL THAT IS GOOD AND HOLY.... I'M DONE!!
only took 10 hours... few pints of blood, words my kids have never heard before, and grinding, drilling, cutting, and should be welding (just to fill some unneeded holes lol) Have not tried it yet. I still have the air box off. I'm installing the Rennbay headlight kit tomorrow (which is the reason I updated the alternator in the first place). The bolt spread on my alternator is about half a hole to short, so I had to grind out the hole on the bottom alternator mount. There's only about 1/4" of material left on it, but its not in the direction the belt pulls, so it should be ok. Also, I had to add a washer to the back of the pulley to bring it out some. Its a thin (maybe 1/16") 1/2" washer that I had to open up the hole on. Its also not perfectly straight. Its 99% there, but we'll see how long the belt lasts. I don't know if its the case of my "remanufactured" alternator, or the mount on the car. The bolt goes in straight, so I can't figure out why its crooked, but it is.... a tiny bit. Thankfully I didn't need to mess with the holes in the original mount, so if need be, I can put back the Porsche alternator............ and waste $200 on the Nissan one lol.... whatever. I got the Duralast from Autozone. I think that might be where the differences are between this OP's write up and my debacle. Its got a lifetime warranty, but I think all my drilling and "fitting" might have voided that LOL. If I need to get another one, I'll buy it with cash, then get my core with cash, so they can't take my core money back when they see what's in the box ![]() Goodnight all!
Quote:
#75 | |
Rennlist Member |
Quote:
![]() The only thing I had to do to the alternator is drill and retap one hole on one of the tabs and trim a "ring" off so the bosch pulley would fit on. I think it had a woodruf key but if it's tight you should not need one. As for grinding the mount. You could cut a slot out of it but I wanted to keep as much material as possible. I tried a dremel which failed, then tried a cut off wheel which did a poor job as well. What finally made this easy was a decent angle grinder that ground through the mount like butter. Yes a lot of material needs to be removed however it's not enough to compromise the mount. My alternator is dead on straight so maybe a hole is drilled slight angled on yours. I plan to remove it this winter while doing some other work so I will take some pics of the mount I modified and add to this thread whenever I do it. The spacing on this is so tight and close that tolerances among different factory mounts and brand alternators will make things more or less work to fit this correctly. As in any fab/custom work, it may take an hour or 3 weeks depending how well things fit into place...that's my experience. Just yesterday I had trouble with a different very simple mod fabbing something I have done on many 951's. For some reason it just didn't go as easy as the 15 other times. To anyone else doing this... Use an angle grinder!
| Tags |
| 1968, 1997, 944, 97, alternator, diagram, install, nissan, pic, quest, radio, removal, shortyboy, turbo, tx, wire, wiring |
| Thread Tools | |
