Wanted: Autothority Stage II, Guru or similar chips.
Looking for a quick easy boost in performance on an otherwise stock car.
I will consider going Vitesse in the future, but that'll be when I need a chip 'tailored' to my car, so for now I want a simple plug'n'play.
APE II with banjo bolt, or other similar chip.
Edit.... I have an '86 951, so 24 pin chips.
Jane Bond 007
It was setup for a stock 951, AFM with a K26. I used a similar set with 18# of boost with good AFR of around 11.5 under boost. I normally ran around 15-16#, the 18# was at Mid-Ohio towards the end of the year, very cool day. I have gone to a different setup after I went to a larger Turbo but I had no issues with these chips. They had a marked improvement over the stock or Autothority ICs.
Guru (Danno) used TT’s software to make these ICs. Not sure Danno squared up the money end with TT before he went out of business which is a shame. TT knows the Motronic setup for the 951 as good as anyone out there.
To everyone who replied via PM, thank you. I'll try to send replies personally.
I have decided on and already purchased a chip set from a member that didn't reply to this thread.
Anyone else who was looking at this, hoping to snag their own chip, you might want to contact some of these people, as there are some good deals to be had.
