Do-It-Yourself LED dash lighting upgrade (writeup)
Old 12-12-2007, 07:53 PM
  #31
chitown928s4
chitown928s4's Avatar
Eniac,
I've tried the 12" UV cathode tubes and they worked and looked awesome for 2 days them they burned out. My current fix is a LED strip light mounted just above the reflectors.
heres the old post of my blue LED strips...
https://rennlist.com/forums/924-931-944-951-968-forum/351460-led-cluster-mod.html
heres my catahode thread
https://rennlist.com/forums/924-931-944-951-968-forum/304375-instrument-dim-light-cluster-fix-for-under-11-a.html
I should take a pic of my current white LED strip that looks better than the blue.
Old 12-13-2007, 01:34 PM
  #32
krazE
krazE's Avatar
So you can just buy 3 of the following and be good? (for the instrument panel)
T1.5 Instrument LED bulb
1-LED Instrument Cluster and Gauge illumination bulb. #74 LED bulb installed in twist-lock socket base Available with White,Blue,Green,Red and Amber Wide Angle LED
Old 12-15-2007, 11:41 PM
  #33
eniac
eniac's Avatar
Sorry for the delay but I got really busy the last fews days. Here are a couple pics. Excuse the poor quality as even the best digital camera will not do well in the dark with low batteries. lol
Ill have to find the store I bought my lights from to see exactly what they are. Something like what you would find in the ricer isle at pepboys would be likely to be the same. I have 3 small tubes so the light is evenly distributed and also isn't too bright as some LED I have seen. A bonus effect is this also makes the orange needles glow as if they were illuminated from the back.
These lights need a regulator which was included. If you connect 13.5v to the lights directly they will be very bright, overheat, and burn out quickly.
The pic is blurry because my camera battery is almost dead
Here is a pic with the flash on and the lights off for comparison.
Old 12-16-2007, 12:13 AM
  #34
IanS
IanS's Avatar
When I did this, I found that adding the reflective tape to the underside of the pathways doubled the light output, and was really worthwhile. I was using 'bulbs' from superbrightleds.com, and without the double-silvering, it wasn't bright enough for my taste.
Old 12-17-2007, 01:15 PM
  #35
ausgeflippt951
ausgeflippt951's Avatar
Anyone have an idea how it'd look w/ red LEDs?
Old 12-17-2007, 01:46 PM
  #36
Cory9584
Cory9584's Avatar
how many bulb locations are there to do the cluster?
Old 12-17-2007, 02:02 PM
  #37
aribop
aribop's Avatar
There are 3.
Old 12-17-2007, 02:07 PM
  #38
aribop
aribop's Avatar
Look here:
http://www.flamingeye.co.uk/coloursred.htm
Old 12-17-2007, 02:39 PM
  #39
PorscheDude1
On the Radar
PorscheDude1's Avatar
Originally Posted by VWaddict
My next step is to attack the climate control and defrost switches etc. I'll be taking pictures and noting polarity etc. I think that 5MM LEDs should be able to fit, although there'll need to be a 500Ω current limiting resistor in line with one of the legs... -The good thing is that they should never burn out, so it would be a one-time deal, rather than occasionally replacing burned-out incandescent bulbs.
Keith
Have you done this yet? This is the only thing keeping from the LED upgrade. I want all of the dash lights to be uniform.
Old 02-13-2008, 11:48 PM
  #40
vdub
vdub's Avatar
+1
Keith, any update on led-ing the remainder of your dash?
Old 02-14-2008, 12:25 AM
  #41
VWaddict
VWaddict's Avatar
Ah not yet, sorry.
Actually, I need to dig the 951 out and put some miles on it... Will do that tomorrow morning, I'm ashamed to confess that it's been languishing in the garage while I've been unfaithful to it...
Keith
Old 03-07-2008, 05:40 AM
  #42
Robby
Robby's Avatar
Keith-
Have you had a chance to mess w/your climate control yet? I had my instrument cluster converted to LED's by NH Speedo- I think they used 7 bulbs & am not sure where they put them, etc- I thnk Brian (Perry951) used 7 too. Anyway, my NH Speedo's are too bright, even w/the rheostat set to full dim. When it's at full bright, other cars can shut off their headlights & use my car to illuminate the street ahead of them How bright are your's? Will the rheostat shut them off completely when you turn it all the way down? I'd like for this to happen- have them blacked out entirely at lowest setting & have them a touch brighter than stock, at brightest...
My main interest in LEDs was to have a cleaner looking cluster w/maybe a tiny bit more brightness. Now I'm trying to pick the right resistor, but I'd prefer to have the entire climate control converted to LEDs & then worry about dialing the perfect brightness range in. IF you're doing the climate control &/or clock, etc, would you be willing to convert other people's cars? I'd be glad to pay to have mine done. Good job on the write-up- the instrument cluster doesn't look horribly tough, but from what I understand, the climate control is more difficult & it's also pretty easy to break & quite expensive...
Old 03-09-2008, 09:57 AM
  #43
gpan951
gpan951's Avatar
Default LEDs for sale on ebay
Hi.
Did the reflectors and changed the bulbs. Good but could be brighter.
Am considering these - 2pcs 501 W5W High Power LED (White) Dash Wedge Bulbs. I saw them on ebay. Loads of different LEDs, colours, LED shapes and prices!
Will post pictures when done.
Gerald
Old 03-09-2008, 10:30 AM
  #44
Luis de Prat
Luis de Prat's Avatar
Hi Robby,
I really think it's better to focus your efforts on the reflectors in the cluster housing, rather than on the source of light itself.
By freshening up the reflectant material in the housing with aluminum foil or similar, and upgrading to 3W bulbs (Porsche parts has superseded the 2W to 3W now, and they won't melt the housing), you'll have more than enough brightness and still retain the rheostat dimmer function.
Keep in mind that bright instrument panel lighting can be tiresome during night driving. You want only enough lighting to be able to read the gauges and minimize your eyesight's adjustment to dark driving conditions.
Old 03-13-2008, 04:46 AM
  #45
Robby
Robby's Avatar
Hey Luis- sorry it's taken me so long to reply- in regards to lighting, it's too late. I already have LED's- I'm still not sure why people say the rheostat (dimmer) does not work w/LEDs though- mine works fine- just like stock, only the dimmest setting is still WAY TOO BRIGHT! I completely agree about the brightness situation- I like to be able to raise it up a little sometimes & then tone it way down others- unfortunately, Porsche did not set our rheostat so that it could completely black everything out. Is there a way to do this?
Still, my situation- I've been told two dif resistors to use & am not sure which to try OR if there's a better way...? I'd just like to reduce the brightness by ~40% or so, across the entire range....
Quick Reply: Do-It-Yourself LED dash lighting upgrade (writeup)
