What would cause all 4 injectors to dump way too much fuel?
Old 12-18-2007, 10:19 PM
fast951
fast951's Avatar
Unplug one injector at a time, see if you can start the car. A 3bar FPR will not cause the problem you are experiencing. Note that wet plugs will cause a no start. Good luck!
John
Email
www.vitesseracing.com
Old 12-18-2007, 10:22 PM
xsboost90
xsboost90's Avatar
are you getting proper spark- no spark - real rich... Recheck dist cap, rotor, coil wire is on properly- basics.
Old 12-19-2007, 02:52 AM
nize
nize's Avatar
how have you confirmed all four injectors are dumping too much fuel?
Old 12-19-2007, 12:44 PM
Ian Carr
That Guy
Ian Carr's Avatar
O2 sensor?
Old 10-04-2008, 09:46 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
What did this turn out to be? My car is doing the same thing.
Old 01-07-2009, 11:35 AM
Synth
Synth's Avatar
Bump, I've got a very similar issue also, and am curious what the remedy turned out to be.
I'm going to try the 02 sensor tonight, and hopefully try swapping DMEs this weekend.
Old 01-07-2009, 11:43 AM
MM951
MM951's Avatar
In my case I had a flaky maxtronic box....Took almost a year to get that sorted out
Russell sent me some chips and the car has started every time and runs OK. Now if I could have a working maxtronic and tune the car....
What mods do you and Michelle have? Hope this helps and good luck in solving the problem..
Quick Reply: What would cause all 4 injectors to dump way too much fuel?
