How much horsepower do you estimate I have?
I bought this car with the following list of performance mods. So far I haven't done any myself- I've been doing repair and restoration. I haven't done any dyno testing so I don't know what power it is making. It is very difficult to hook up the tires in first when the turbo spools up and it rips through second in no time, but I have no idea what kind of numbers it's making. just curious really; what do you guys think?
Engine Mods:
- Split Second ARC-2 Air/Fuel Computer
- Split Second ARM-1 Air/Fuel Meter
- Guru Racing DME and KLR Chips
- Speed Force Racing Stage III Mass Air Flow kit
- K&N Air Filter
- Greddy Type-S Blow-off Valve
- Speed Force Racing 2.5” intercooler pipes
- Speed Force Racing Cat-back exhaust
- 3" Bullet Exhaust Tip
- Tial 38mm Wastegate
- Manual Boost Controller
- Lindsey Racing Vacuum Hose Kit
- Lindsey Racing Fuel Pressure Gauge on Fuel Rail
- Adjustable Fuel Pressure Regulator
- Widefire Head Gasket
- Rebuilt long block
- Rebuilt OEM Turbo
Right now I'm running at 13 PSI boost.
Here's a picture of when I first got it.
Engine Mods:
- K&N Air Filter
- Rebuilt OEM Turbo
I would think at 13 psi with a 26/6 at best about 220 rwhp. But you need good tuning. I made with my 26/6 230 rwhp@15 PSI and with my 26/8 250 rwhp@15PSI.
Guru chips @ 15 psi
Test pipe
Reliaboost
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/103586-my-dyno-sheets.html
I have the same MAF.. Do you have a problem with stumbling/bucking ~2-3K rpm in 3rd,4th,5th? It runs great in boost.. just lower rpms off boost it does not like it. From my searches it appears that the "clocking" of the "stage 3" maf has a lot to do with it, but I have my MAF postioned the same as yours..
Sorry, I just copied and pasted the list of mods that the guy did on the car.
