I've got an exhaust leak before the turbo..
Wax On, Wax Off
How can I check for cracked headers? I've always suspected it, but today for the first time I had the car running with the hood open, and I've heard it now too... also gonna put it up on ramps and tighten every frickin nut and bolt that I can find under there...
That Guy
best thing i can think of is to put a little oil in the intake and see if it smokes from the headers. I know my exhaust cracked at the Y in the cross over...
never tried oil in the intake but finding leaks is as easy as sticking your hands down there and feeling around (while car is cool of course). I've been able to easily find pinhole leaks this way.
Well the slightly more expensive way (but most sure fire) is to find a shop or something with access to a smoke diagnostic machine. Stick it in the tail pipe and eventually you will see a thick white smoke emanating from any leaks in the system. Same can be done with the intake track.
Drive-by provocation guy
Cast Iron Man
While the car is COLD start it up and spray soapy water on the headers with a hand held spray bottle (like a windex bottle). It will bubble up if there is a leak.
-M
-M
Wax On, Wax Off
Ok. I'm gonna go look.
friend last night (in a parking lot) blocked it off with his bare hand for like, 3 seconds after a spirited drive. I'm surprised he lasted that long...
Wax On, Wax Off
oK. so here's what I found- #1 and #2 cylinder head to header had loose nuts. they've been tightened. Also, on the exhaust side of the turbine, 2 of the 4 bolts holding that down were very loose, as in nearly falling off... since it's on the exhaust side of the turbine, I can't see it being parasitic, but I bet that's where my spooling sound is coming from, not to mention it'll be a hell of a lot safer to bolt those back down... Carbon monoxide poisoning isn't fun.
and Mike, burning soap smells REALLY bad. thanks
