classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#31 |
Rennlist Member Join Date: Jul 2007
Don't use an orbital.
look for a polisher (low speed 7" grinder, B&D and the like) and a wool pad. I would also recommend using 3M finnessit II to buff with I've painted cars for years and I can see how this does work. It would work especially well using a high quality paint if it were a solid color. The rustoleum stuff doesn't hold out it's gloss near as long as the automotive paints do. But it does work for a better than Maaco job for sure. When I do a real high dollar piece (or did) I would use extra material so it could be buffed for years. Honestly it didn't matter how the finished spray looked (peeled,dry or other) b/c in the end it is sanded down and buffed anyway. good outa the box thinking. Not my first choice but it would work quite well for a track type car.
![]() ![]() ![]() Sid- 87 951 Rogue tuned,Holset HX35 custom turbine, currently running 25 psi, 83 Mule project..getting there... almost 11:1 compression with quick spool turbo,96# injectors,modified 951 IC, ~2350#'s All E85 01 Audi 4.2 Quatro |
#32 |
Rennlist Member |
How long did you wait between coats?
Kevin 1989 951, Leinengrau Metallic - 1986 Engine, K27/6, Lindsey Stage 2 MAF, Seimens 55lb injectors, TiAL 38mm, LBE, Vitesse Software, Himsel Haus Fuel Lines (Happy?), 3 bar FPR, SPEC Stage II Clutch, Fabspeed SS 3" Exhaust, 33/5 Bias Valve, Uego WBO2, VDO EGT, KLA Strut Brace, Loose nut behind the wheel. 1990 M3, Sterlingsilber Metallic 1988 Volvo 240DL, Vit |
#33 |
Rennlist Member Join Date: Dec 2002
I let it dry overnight and put a fan in the garage to help circulate air.
Blown, I do intend to put some clear coat on it when the time comes but like I said, its a once a week driven car. I'm probably not going to track it and just for riding down the road, any little imperfections aren't going to be too noticeable. Thanks for the advice. |
#34 |
Rennlist Member Join Date: Jul 2006
So are you supposed to sand it down afterwards?
#35 |
#36 |
Rennlist Member Join Date: Dec 2005
Dan, glad to see you made it back in one piece. the paint job looks great. did you do any bodywork on the passenger side?
#37 |
Thanks John. Yep I used some Bondo glazing putty to smooth out what that guy did to it so it's not 100% percent but you'd never notice if you weren't looking.
#38 |
Rennlist Member Join Date: Nov 2004
After you wetsand, do you polish it out (with compound or other polish) then put on second coat? or you leave it hazy after wetsand and reapply another coat of paint?
Nice work!
Joe 1995 Porsche 993 Polar Silver 1987 Porsche 944S Black 1998 Porsche Bike S Guards Red |
#39 |
Rennlist Member |
Sweet. I may do this on the front end of the camry since it has all those damn rock chips.
Bill Andrew 1986 951 - 50mph to 90mph in 3.4 sec 93 Camry - 260k mi and counting ![]() auto tech at Dietschwerks in Santa Clara |
#40 |
Nope, you don't use polish until the very end. Leave it hazy then paint another coat.
#41 |
Rennlist Member Join Date: Oct 2002
I told my friend about this paint that you put on with a roller and his reply was when I sober up to call him in the morning.
1988 Red Turbo S /Guru chips/reliaboost/Magnaflow exhaust 2003 YZ 250R |
#42 | |
Rennlist Member Join Date: Apr 2003
Quote:
Is this ("Protective Enamel") what you used? http://www.rustoleum.com/CBGProduct.asp?pid=150
"OBJECTS IN MIRROR APPEAR TO BE LOSING" FOR SALE '86 951 (updated to "S") - 2008 Mid-Atlantic 944 SuperCup Champion and Summit Point/NJMP Lap Record Holder |
#43 |
Rennlist Member Join Date: Dec 2007
thats beautiful. I was going to buy that, but you live closer!
#44 | |
Quote:
#45 |
User
Nice work Dan. Read the post on the mopar forums, which was informative. What steps did you take to prep the car before painting?
| Tags |
| blue, buffer, car, cars, enamel, graphite, grey, interior, long, protective, race, rustoleum, sail, smoke, wheel |
| Thread Tools | |
