Got my 2.7 big bore!
Old 05-04-2008, 03:23 PM
theedge
theedge's Avatar
Default Got my 2.7 big bore!
I got my 2.7 liter MID block back from Mr White
Wossner pistons, Calico coatings on the side and top, all the bearings are Calico coated, MLS headgasket, balanced the bottom end, and some cylinder head work to fix the last shops screw up (who doesnt clean a cylinder head out after machining, or center the O-Rings better?). Ive got an IJ windage tray coming too, and gobs of other parts.
Also theres pics of the -10 AN fuel rail extrusion, Deutsch Autosport firewall connectors, and misc other stuff.
Enterprise gave me a Dakota with a V8 for $30 ;-)
Old 05-04-2008, 03:27 PM
theedge
theedge's Avatar
Old 05-04-2008, 03:29 PM
David Floyd
David Floyd's Avatar
Old 05-04-2008, 03:42 PM
MM951
MM951's Avatar
That is gonna be one fun car
Old 05-04-2008, 08:10 PM
Ski
Ski's Avatar
Very nice! I see lots of Redline assembly lube - good stuff!
What spring rates did you end up with on the Bilsteins?
Old 05-04-2008, 08:47 PM
DanG
DanG's Avatar
Looks good Brian. How much did those connectors run you?
Old 05-04-2008, 09:03 PM
Darwantae951
Darwantae951's Avatar
Ok, keeping in mind that I know nothing about BUILDING an engine like this, what's the importance of the redline assembly lube?
Old 05-04-2008, 09:13 PM
Techno Duck
Techno Duck's Avatar
Anything that is usually coated in oil must be coated in assembly lube prior to startup. This prevents any metal to metal contact.
Old 05-04-2008, 10:25 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Looks great. Building the motor is half the fun! What kind of turbo is that waiting on the shelf?
Old 05-04-2008, 10:38 PM
theedge
theedge's Avatar
50-60 UK pounds each
www.m-cal.com. www.p-r-s.com carries them as well about the same price.
theedge
theedge's Avatar
Vitesse Stage 2
Old 05-04-2008, 10:39 PM
theedge
theedge's Avatar
I think 400 on the front, 300 on the rear. Id have to check. I got them used from someone who had tbars, so ill have to change the rear springs out to a more suitable rate for my tbar delete.
Old 05-04-2008, 10:46 PM
Tom M'Guinn
Originally Posted by theedge
Vitesse Stage 2
That should be a mighty quick spool on a 2.7. My stage 5 is seeing 19psi by around 3k rpms on 3019cc's. Driving it is the only thing better than building it.
Old 05-05-2008, 04:02 AM
nize
nize's Avatar
nice! what are your power goals?
Old 05-05-2008, 10:01 AM
Josh B
Josh B's Avatar
Sweet!
Quick Reply: Got my 2.7 big bore!
