E-85 MEGA THREAD
Old 11-09-2008, 09:20 PM
  #31
blown 944
blown 944's Avatar
awesome did you log knock counts??
If so where did you end up for timing @11.5 AFR at high boost for that turbo??
I always like to know the end result of each setup........nosey
Old 11-09-2008, 10:11 PM
  #32
jlturpin
jlturpin's Avatar
I did not get "that" aggressive with timing and there was no Knock detected. I think there is still timing to be added, especially after the turbo begins to drop off. I'll look at my datalog and see what it looks like, I know it pulled like crazy and I have never felt the k26/6 pull like that. Will post more later.
Old 11-09-2008, 11:41 PM
  #33
jlturpin
jlturpin's Avatar
Pulling through a few gears, E85. You should be able to see RPM, Boost, AFR and Timing advance.
Old 11-09-2008, 11:59 PM
  #34
blown 944
blown 944's Avatar
that looks pretty good
you may try to add a little fuel up top looks like it may be close to 12:1
actually you could add a little from boost onset and add some timing there too.
just pay attention to knock counts.
You will certainly need to retune with the other turbo for sure as it is dropping off and it looks slightly lean now in the upper rpms it will be much worse with the added cooler air.
What is your rev limiter set at.
Old 11-10-2008, 01:43 AM
  #35
95ONE
95ONE's Avatar
Simple steps to prepare for E-85.
replace any old fuel lines to new stock. Don't worry about them for another 5 years.
upgrade injectors and fuel pump to around 40% (safely) More capacity than would be needed for gasoline.
Tune ignition timing like it was on race fuel.
Re-tune AFR's to .8 lambda.
Spend lots of time on the cold start up map..
you're done. .... seriously.
Old 11-10-2008, 01:55 AM
  #36
DanG
DanG's Avatar
Here is a Megasquirt website about the flex fuel sensor found on GM vehicles that allow for automatic compensation to whatever blend of regular pump gas and E85 you may have in the tank...
http://www.megamanual.com/flexfuel.htm
Old 11-10-2008, 06:07 AM
  #37
jlturpin
jlturpin's Avatar
That bad bod is like $400 dollars, great idea and I thought about it until I did my first search and saw the price.
Old 11-10-2008, 06:12 AM
  #38
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
What air/fuels am I looking for on my AEM(uego) wideband when I start tuning with E-85?
Old 11-10-2008, 07:18 AM
  #39
333pg333
333pg333's Avatar
So is this sensor something that can be fitted to any car?
Old 11-10-2008, 07:21 AM
  #40
333pg333
333pg333's Avatar
...and what do we think about this??
http://flexfuelus.com/
Old 11-10-2008, 07:50 AM
  #41
porshhhh951
Damn
Old 11-10-2008, 09:14 AM
  #42
Duke
Duke's Avatar
The flexifuel sensor looks just like a lambda sensor. But you need an EMS that can run it.
DTA has inbuilt functionality to run a flexifuel sensor. Should be able to do something similar with the Link G4 storm if you're creative.
Old 11-10-2008, 09:33 AM
  #43
jlturpin
jlturpin's Avatar
WOW, 1200-1300 dollars. Not gonna happen for me.
Old 11-10-2008, 10:57 AM
  #44
blown 944
blown 944's Avatar
read back to the first page .... those numbers should apply to your wideband as it is calibrated
Old 11-10-2008, 11:59 AM
  #45
porshhhh951
Figures i'd get owned in my own thread. I thought the values were different for the AEM style units.
Something strange like 8.5/9ish a/f.
11.5 is the same a/f im shooting for, for pump fuel. So what you're saying is the values on my readout are going to remain the same between pump fuel and E-85? I never would have thought that.
Quick Reply: E-85 MEGA THREAD
